puma Posted May 6, 2015 Report Share Posted May 6, 2015 görev yöneticisine giremiyorum devre dışı bıraktığımı söylüyor. Formlarda bu sorunu nasıl düzelteceğimi anlatıyorlar,ama nedense gpedit.msc ye ulaşamıyorum.Ve son günlerde ekrana bu siyah panel açılıyor.http://prntscr.com/7238nvne yapabilirim yardımcı olursanız sevinirim. translated from turkish registry I'm not allowed to say I disable the task manager. They tell me how to fix this problem in the form, but for some reason I can not get GPedit.msc eat. And it opens the black panel screen in recent days. http://prntscr.com/7238nvn to I am glad if I can help. error message: kayit defteri düzenleyicisi - the registry editor kayıt defteri düzenleme yöneticiniz tarafından devreden çıkarılmış - deactivated by editing the registry administrator error in english: registry editor registry editing has been disabled by your administrator Operating system:Windows 7 Ultimate (32 bit) Service Pack 1 System root: C:Windows Available physical memory: 1788 MB CPU: AMD Athlon II Dual-Core M320 Drive Info: C: 144,99 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted May 6, 2015 Report Share Posted May 6, 2015 Hi puma. 1) Have you tried to run regedit from C:\Windows? 2) Have you already used the solution proposed by wise pc 1st aid about that problem? 3) Have you already tried to use gpedit.msc (available only on professional/ultimate/enterprise versions)? - Windows key + R key opens the run window, type gpedit.msc, press enter - go to User Configuration --> Administrative Templates --> System, in the right pane select Prevent access to registry editing Tools and set it to Not configured or Disabled. 4) Have you already tried the other tools listed in techdows.com - 7 Ways to Fix ”Registry editing has been disabled by Your administrator “ (click) ? Link to comment Share on other sites More sharing options...
