muharrem Posted April 4, 2015 Report Share Posted April 4, 2015 Help And Support cant start there is a problem Operating system:Windows 7 Professional (64 bit) Service Pack 1 System root: C:Windows Available physical memory: 3823 MB CPU: AMD Athlon Dual Core Processor 5200B Drive Info: C: 63.38 GB D: 85.57 GB G: 0.01 GB Internet Explorer: 8.0 Ekbergwef 1 Link to comment Share on other sites More sharing options...
xilolee Posted April 4, 2015 Report Share Posted April 4, 2015 Hi muharrem. This problem is usually solved by the MS SFC tool (system file checker). Launch sfc /scannow from an elevated command prompt, wait till it finishes and see whether the problem disappears. If not, reboot your machine and re-check. Looking forward for your kind feedback! How to run an elevated command prompt for Windows vista/seven users One of these three methods: - click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear Link to comment Share on other sites More sharing options...
