Posted
1.) Video will no longer play regardless whether Vlc, Smplayer or Windows media player used.
2.) Pixalation began a month ago and I attempted to update the AMD Radeon driver.
3.) Screen now refreshes every minute closing some Windows files I have open.
System root: C:Windows
Available physical memory: 4007 MB
CPU: Intel® Core i7-2675QM CPU @ 2.20GHz
C: 119.08 GB
E: 811.63 GB
G: 1863.01 GB
H: 1862.98 GB
I: 232.88 GB
Internet Explorer: 11.0
Posted
Hi lincoln101.
Download and run
System Update Readiness Tool for Windows 7 for x64-based Systems (KB947821) [October 2014]
From an elevated command prompt, launch (Windows installation cd could be necessary):
sfc /scannow
Wait till it finishes (15-50 minutes).
If the final result is equal to Windows Resource Protection did not find any integrity violations or equal to Windows Resource Protection found corrupt files and successfully repaired them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch this command:
copy %SYSTEMROOT%\Logs\CBS\CheckSUR.log "%userprofile%\desktop\CheckSUR.txt"
After it, you should find checkSUR.txt on your desktop: post it here.
Instead if the final result of the SFC TOOL is equal to Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch both the previous command in the code above AND also this command:
copy %SYSTEMROOT%\logs\cbs\cbs.log "%userprofile%\desktop\cbs.txt" && findstr /c:"[SR]" "%userprofile%\desktop\cbs.txt" > "%userprofile%\desktop\SR.txt"
After those two commands, you should find three files on your desktop: checkSUR.txt, cbs.txt and SR.txt: post here the checkSUR.txt and the sr.txt.
If the last command won't work, try these (one by one):
How to run an elevated command prompt for Windows vista/seven users
One of these three methods:
- click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear
- click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear
- click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear
