whitesmay Posted February 15, 2015 Report Share Posted February 15, 2015 Arkadaşlar öncelikle Sa arkadaşlar sorun giderme çalışmıyor resimde gördüğünüz gibi hata alıyorum.Ne yapsam olmadı bilen biri varsa yardım ederse sevinirim. :( translated from turkish When troubleshooting an error occurred Help Me !!!!! Friends first I get an error as you can see in the picture SE friends troubleshooting does not work. What if I did I would be glad if anyone knows if there will help. :( screenshot: Windows Ağ Tanılama Sorun giderirken bir hata oluştu: Beklenmedik bir hata oluştu. Sorun giderme sihirbazi devam edemiyor. Paket kimliği: networkdiagnostics Yol: c:\windows\diagnostic\system\networking Hata kodu: 0x80070002 Kaynak: Altyapi Kullanici: HAKAN-PC\HAKAN Bağlam: Yükseltilmiş Button: Kapat possible english error message Windows Network Diagnostics An error occurred while troubleshooting: A problem is preventing the troubleshooter from starting. Package ID: networkdiagnostics Path: c:\windows\diagnostic\system\networking Error code: 0x80070002 Source: Infrastructure User: HAGAN-PC \ HAGAN Context: Elevated Button: Close Operating system:Windows 7 Ultimate (32 bit) System root: C:Windows Available physical memory: 3237 MB CPU: Intel® Core i7-2630QM CPU @ 2.00GHz Drive Info: C: 465,66 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted February 16, 2015 Report Share Posted February 16, 2015 From an elevated command prompt, launch these commands: sc config cryptosvc start= auto sc start cryptosvcAnd re-try to run the troubleshooter. Keep us updated. How to run an elevated command prompt for Windows vista/seven users One of these three methods: - click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear Link to comment Share on other sites More sharing options...
