2537582804 Posted February 12, 2015 Report Share Posted February 12, 2015 我的电脑非常的卡 translated from chineseMy computer is too cardMy computer is very card Operating system:Microsoft Windows XP (32 bit) Service Pack 3System root: C:WINDOWSAvailable physical memory: 1791 MBCPU: AMD Sempron X2 190 ProcessorDrive Info:C: 50.01 GBD: 100.01 GBE: 151.01 GBF: 149.71 GBInternet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted February 12, 2015 Report Share Posted February 12, 2015 didn't understand Link to comment Share on other sites More sharing options...
云淡风轻 Posted February 14, 2015 Report Share Posted February 14, 2015 硬件配置过低,如果安装的软件比较多,卡是正常的。建议你换台新电脑吧,通常意义的电脑加速/清理,对你来说效果不明显。 当然,你也可以根据这个帖子的方法进行优化,会有一定效果。 how to speed up your pc Hardware configuration is too low, if you install more software, card is normal. I suggest you change a new computer now, in the usual sense of the computer up / clean-up, for you, is not obvious. Of course, you can also be optimized according to the method of this post, there will be some effect. how to speed up your pc Link to comment Share on other sites More sharing options...
