garcia.ortega.1 Posted February 9, 2015 Report Posted February 9, 2015 wise care takes to long to long to start at start last startup was 252 sed. Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:Windows Available physical memory: 1900 MB CPU: Intel® Celeron® CPU B800 @ 1.50GHz Drive Info: C: 279.47 GB D: 14.46 GB E: 3.96 GB Internet Explorer: 8.0 MichaelCyday, Rustyamins and ThomasEn 3
xilolee Posted February 9, 2015 Report Posted February 9, 2015 That's strange. What version are you using? The latest one is 3.4.5 (or 3.45.302)... Excluding the BETA version. Free or pro? Installed or portable? Where did you download it from?
garcia.ortega.1 Posted February 16, 2015 Author Report Posted February 16, 2015 wise care isn't set up to run at start?wise cleaner isn't setup to run at start u have start manuallyOperating system:Windows 7 Home Premium (64 bit) Service Pack 1System root: C:WindowsAvailable physical memory: 1900 MBCPU: Intel® Celeron® CPU B800 @ 1.50GHzDrive Info:C: 279.47 GBD: 14.46 GBE: 3.96 GBInternet Explorer: 8.0 having trouble with ie i use chrome Version 40.0.2214.111 m
xilolee Posted February 17, 2015 Report Posted February 17, 2015 What version are you using? The latest one is 3.4.5 (or 3.45.302)... Excluding the BETA version. Free or pro? Installed or portable? Where did you download it from?
