fritz Posted January 10, 2015 Report Share Posted January 10, 2015 Hallo, ich bin neu hier und habe zwei Fragen. 1. kann man hier in diesem Forum die Sprache auf Deutsch umstellen ? 2. wo legt Wiese die Backup-Dateien ab ? Bin gespannt auf die Antworten. VG.. Fritz translated from german two questions Hello, I'm new here and I have two questions. 1. you can here in this forum change language in German? 2. where sets meadow from the backup files? I'm curious about the answers. VG .. Fritz Rustyamins and AcucaEn 2 Link to comment Share on other sites More sharing options...
xilolee Posted January 10, 2015 Report Share Posted January 10, 2015 Hi Fritz. 1) No, you can't change the forum Language 2) Did you intend "where is the backup folder?" ? It should be in your wise care 365 folder, if you have downloaded the portable version or in the following folder if you installed wise care 365 in your machine: %appdata%\Wise Care 365\Backup c:\users\%username%\appdata\roaming\Wise Care 365\Backup%appdata% = c:\users\%username%\appdata\roaming%username% = your user name Link to comment Share on other sites More sharing options...
fritz Posted January 11, 2015 Author Report Share Posted January 11, 2015 Hei Xilo, Danke für die Antwort. Leider beherrsche ich die Englische Sprache nicht. Deshalb werde ich mich von diesem Programm verabschieden. Es ist schade, ich war damit eigentlich sehr zufrieden. MfG. Fritz translated from german Hei Xilo, Thanks for the reply. Unfortunately I do not speak the English language. Therefore, I will say goodbye to this program. It's a shame, I was actually very happy with it. MfG. Fritz Link to comment Share on other sites More sharing options...
xilolee Posted January 11, 2015 Report Share Posted January 11, 2015 The language of wise care 365 can be set to german. Only the forum hasn't got this possibility. Link to comment Share on other sites More sharing options...
fritz Posted January 11, 2015 Author Report Share Posted January 11, 2015 Xilo, ja das ist mir klar, aber genau darum geht es mir ja. translated from german Xilo, yes that is clear to me, but that's what me so. Link to comment Share on other sites More sharing options...
