montalvao Posted January 4, 2015 Report Share Posted January 4, 2015 baixei o programa para terntar resolvero a lentidao do mesmo mas ficou pior apos ter utilizado. translated from galician pc slowed after use downloaded the program to try to solve the slowness of it but it got worse after using. Operating system:Windows 8.1 Pro (32 bit) System root: C:Windows Available physical memory: 3191 MB CPU: Intel® Pentium® Dual CPU E2160 @ 1.80GHz Drive Info: C: 148,71 GB D: 146,39 GB F: 151,60 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted January 4, 2015 Report Share Posted January 4, 2015 What program did you download and try? Check the following topics: How to speed up your PC by WiseCleaner_Admin How to speed up a computer; speed up any PC or laptop (Part One) by Linkin How to speed up a computer; speed up any PC or laptop (Part Two) by Linkin Or try these operations: 1) If the warranty has expired, you could try to open your PC (first unplug it from the mains...!) with a lot of caution and, gently, remove the dust with a brush and vacuum cleaner (or hair dryer) and apply the thermal paste to the processor. 2) Open an elevated command prompt and type: cleanmgr /sageset:1 Press enter, tick every option (or the options that you prefer) inside cleanmgr advanced menu, click ok, then type this: cleanmgr /sagerun:1Press enter and wait until it finishes. 3) Download adwcleaner portable (click) and run it. 4) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 5) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it) 6) Double left-click wisecare365.exe, click (top right corner) custom --> settings --> custom checkup, select/tick all entries (or the entries that you prefer), click save, click checkup, wait until the scan finishes, click fix. 7) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) 8) Launch sfc /scannow from an elevated command prompt (and report the result here) 9) Defrag your hard disks (it may take hours... Try first the OS partition only). If you often get BSODs, skip this. Keep us informed. Link to comment Share on other sites More sharing options...
