Xiaoshu Posted January 4, 2015 Report Share Posted January 4, 2015 嘗試過Ctrl+alt+Delete 及許多方法都無法開啟工作管理員 是在掃毒後才出現的問題 translated from chinese Unable to open the Task Manager, absolutely no reaction Tried Ctrl + alt + Delete And many methods are unable to open the Task Manager In antidrug after problems Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:WINDOWS Available physical memory: 3464 MB CPU: Intel® Celeron® CPU G1820 @ 2.70GHz Drive Info: C: 75.13 GB D: 382.64 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted January 4, 2015 Report Share Posted January 4, 2015 Did you also try the solution about it in wise pc 1st aid? Link to comment Share on other sites More sharing options...
云淡风轻 Posted January 8, 2015 Report Share Posted January 8, 2015 除了Ctrl+Alt+Del的方式外,还可以用Ctrl+Shift+Esc的组合键来打开任务管理器 如果都打不开,按Win+R打开运行窗口,输入taskmgr.exe,看能不能打开任务管理器 translated from chinese In addition to Ctrl + Alt + Del way, you can also use Ctrl + Shift + Esc key combination to open the Task Manager If you are not open, press Win + R to open the Run window, type taskmgr.exe, see if you can open the Task Manager Link to comment Share on other sites More sharing options...
