Rahaf Posted December 31, 2014 Report Share Posted December 31, 2014 عند استخدام الحاسوب بعد فترة وجيزة من استخدامه وأحياناً بعد فترة طويلة يطفئ الحاسوب نفسه فجأة وقصراً لم استطع ايجاد أي سبب لزلك وتمت صيانته ولم يجدو قطعة مضروبة translated from arabic Computer stops working When you use a computer after a brief period of use, and sometimes after a long period extinguish the computer itself suddenly and stately homes I could not find any reason to do so and has maintained and did not find a piece multiplied Operating system:Windows 7 Ultimate (32 bit) System root: C:Windows Available physical memory: 1907 MB CPU: Intel® Core i3 CPU M 380 @ 2.53GHz Drive Info: C: 58.59 GB D: 136.62 GB E: 102.78 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
xilolee Posted January 1, 2015 Report Share Posted January 1, 2015 Check the following topics: How to speed up your PC by WiseCleaner_Admin How to speed up a computer; speed up any PC or laptop (Part One) by Linkin How to speed up a computer; speed up any PC or laptop (Part Two) by Linkin Or try these operations: 1) If the warranty has expired, you could try to open your PC (first unplug it from the mains...!) with a lot of caution and, gently, remove the dust with a brush and vacuum cleaner (or hair dryer) and apply the thermal paste to the processor. 2) Open an elevated command prompt and type: cleanmgr /sageset:1 Press enter, tick every option (or the options that you prefer) inside cleanmgr advanced menu, click ok, then type this: cleanmgr /sagerun:1Press enter and wait until it finishes. 3) Download adwcleaner portable (click) and run it. 4) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 5) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it) 6) Double left-click wisecare365.exe, click (top right corner) custom --> settings --> custom checkup, select/tick all entries (or the entries that you prefer), click save, click checkup, wait until the scan finishes, click fix. 7) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) 8) Launch sfc /scannow from an elevated command prompt (and report the result here) 9) Defrag your hard disks (it may take hours... Try first the OS partition only). If you often get BSODs, skip this. Keep us informed. Link to comment Share on other sites More sharing options...
