pankajsinghal 1 Posted December 27, 2014 Report Share Posted December 27, 2014 "bluestacks program" install kyo nahi ho rha h. yeh kyo dikha rha h. kya yeh windows xp hone ke karn to nahi ho rha. translated from hindi "ब्लूएसटैक प्रोग्राम" इनस्टॉल क्यों नहीं हो रहा ह. यह क्यों दिखा रहा ह. क्या यह विंडोज ष्प होने के कारण तो नहीं हो रहा. "Bluestacks program" has been installed not. Why are showing. Due to it not being Shp Windows. please tell me. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:WINDOWS Available physical memory: 1015 MB CPU: Intel® Pentium® 4 CPU 2.00GHz Drive Info: C: 35.16 GB D: 40.04 GB E: 44.56 GB F: 29.29 GB Internet Explorer: 8.0 Dwaynegear 1 Link to post Share on other sites
xilolee 511 Posted December 27, 2014 Report Share Posted December 27, 2014 Your pc has got 1GB ram only. Windows XP (32-bit only) installation requirements You can install the BlueStacks App Player on Windows XP (32-bit only) installations as long as the following requirements are fulfilled: 1.You must be an Administrator on your PC. 2.Your PC must have Service Pack 3 (SP3), or higher, installed. (You can install it through Windows Update) 3.Your PC must have Windows installer 4.5 installed. (You can download it from http://download.microsoft.com/downloa...) 4.Your PC must have .NET Framework 2.0 SP2, (You can download it from http://download.microsoft.com/downloa...) 5.Your PC must have 2GB of RAM/main memory. (Note that having 2GB or more disk space is not a substitute for RAM) 6.Your PC must have 9GB of disk space available for storing Android apps / games and their data. 7.The drivers for your PC's graphics drivers should be updated for compatibility with BlueStacks as described in the following post The App Player is nominally installed in the same drive where Windows is installed, usually C:\. However, during installation, you may choose to have all of the apps/data located on another drive. We do not recommend installing the BlueStacks App Player if you have a virtual machine, e.g., Microsoft Virtual PC, VMWare Workstation, or Oracle Virtualbox, installed on the same PC. Please note that BlueStacks is incompatible with BitDefender, you can install any one but not both of them on the same PC. Thank you Link to post Share on other sites
