cblaster Posted December 22, 2014 Report Share Posted December 22, 2014 A few weeks ago, I ran into a problem where none of my Windows 8.1 tiles that required a connection to the internet would open. I tried reinstalling and reregistering them, and got all to work except for Onedrive. I thought I uninstalled Onedrive, but according to the Microsoft technicial I spoke to, you cannot uninstall it from Windows 8. So, I reinstalled the app from the Windows Store, and every time I open the tile, it shows that it is trying to open the app but it never opens. I even tried to open it from my desktop taskbar but it gives me a runtime error. Link to comment Share on other sites More sharing options...
xilolee Posted December 22, 2014 Report Share Posted December 22, 2014 Right-click start, left-click command prompt (admin), type the following command in the command prompt (the black window), press enter and check if it worked: powershell -ExecutionPolicy Unrestricted Add-AppxPackage -DisableDevelopmentMode -Register $Env:SystemRoot\FileManager\AppxManifest.xml(if not, re-try after you have rebooted the machine) Link to comment Share on other sites More sharing options...
cblaster Posted December 23, 2014 Author Report Share Posted December 23, 2014 Thanks for your suggestion, but it did not work. On two different occasions, I was able to see my files, with a few minutes of waiting -- this was when opening it from the Windows tile. When opening it from my desktop I still get that error message. Link to comment Share on other sites More sharing options...
xilolee Posted December 23, 2014 Report Share Posted December 23, 2014 Right-click start, click command prompt (admin), launch: dism /online /cleanup-image /checkhealthIt should last few seconds, then report the final result here.After it, launch: sfc /scannowIt should last 15-50 minutes, then report the final result here.Then launch this command: copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt && findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txtAfter it, you should find two files on your desktop: cbs.txt and SR.txt.Post here the sr.txt . If the command won't work, try these, one after the other (one by one): copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txt Link to comment Share on other sites More sharing options...
cblaster Posted December 24, 2014 Author Report Share Posted December 24, 2014 Thanks for your help. Here is what comes up after the first launch: No component store corruption detected. The operation completed successfully. 2nd launch: Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For example C:Windws\Logs\CBS.log. Note that logging is currently not supported in offline servicing scenarios. In the 3rd launch: C:\WINDOWS\system32>copy %SYSTEMROOT%\logs\cbs\cbs.log > %userprofile%\desktop\cbs.txt && findstr /c:"[sR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\.SR.txt Link to comment Share on other sites More sharing options...
cblaster Posted December 24, 2014 Author Report Share Posted December 24, 2014 Did you need me to give you the entire SR.tx? If so, here it is: 2014-12-23 23:12:10, Info CSI 0000000a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:12:10, Info CSI 0000000b [SR] Beginning Verify and Repair transaction 2014-12-23 23:12:17, Info CSI 0000000c [SR] Verify complete 2014-12-23 23:12:17, Info CSI 0000000d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:12:17, Info CSI 0000000e [SR] Beginning Verify and Repair transaction 2014-12-23 23:12:23, Info CSI 0000000f [SR] Verify complete 2014-12-23 23:12:23, Info CSI 00000010 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:12:23, Info CSI 00000011 [SR] Beginning Verify and Repair transaction 2014-12-23 23:12:29, Info CSI 00000012 [SR] Verify complete 2014-12-23 23:12:30, Info CSI 00000013 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:12:30, Info CSI 00000014 [SR] Beginning Verify and Repair transaction 2014-12-23 23:12:37, Info CSI 00000015 [SR] Verify complete 2014-12-23 23:12:37, Info CSI 00000016 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:12:37, Info CSI 00000017 [SR] Beginning Verify and Repair transaction 2014-12-23 23:12:44, Info CSI 00000018 [SR] Verify complete 2014-12-23 23:12:44, Info CSI 00000019 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:12:44, Info CSI 0000001a [SR] Beginning Verify and Repair transaction 2014-12-23 23:12:51, Info CSI 0000001b [SR] Verify complete 2014-12-23 23:12:51, Info CSI 0000001c [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:12:51, Info CSI 0000001d [SR] Beginning Verify and Repair transaction 2014-12-23 23:12:57, Info CSI 0000001e [SR] Verify complete 2014-12-23 23:12:57, Info CSI 0000001f [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:12:57, Info CSI 00000020 [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:03, Info CSI 00000021 [SR] Verify complete 2014-12-23 23:13:03, Info CSI 00000022 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:03, Info CSI 00000023 [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:08, Info CSI 00000024 [SR] Verify complete 2014-12-23 23:13:09, Info CSI 00000025 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:09, Info CSI 00000026 [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:14, Info CSI 00000027 [SR] Verify complete 2014-12-23 23:13:14, Info CSI 00000028 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:14, Info CSI 00000029 [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:20, Info CSI 0000002a [SR] Verify complete 2014-12-23 23:13:20, Info CSI 0000002b [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:20, Info CSI 0000002c [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:26, Info CSI 0000002d [SR] Verify complete 2014-12-23 23:13:26, Info CSI 0000002e [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:26, Info CSI 0000002f [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:33, Info CSI 00000030 [SR] Verify complete 2014-12-23 23:13:33, Info CSI 00000031 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:33, Info CSI 00000032 [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:38, Info CSI 00000033 [SR] Verify complete 2014-12-23 23:13:38, Info CSI 00000034 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:38, Info CSI 00000035 [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:44, Info CSI 00000036 [SR] Verify complete 2014-12-23 23:13:44, Info CSI 00000037 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:44, Info CSI 00000038 [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:49, Info CSI 00000039 [SR] Verify complete 2014-12-23 23:13:49, Info CSI 0000003a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:49, Info CSI 0000003b [SR] Beginning Verify and Repair transaction 2014-12-23 23:13:55, Info CSI 0000003c [SR] Verify complete 2014-12-23 23:13:55, Info CSI 0000003d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:13:55, Info CSI 0000003e [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:00, Info CSI 0000003f [SR] Verify complete 2014-12-23 23:14:00, Info CSI 00000040 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:00, Info CSI 00000041 [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:06, Info CSI 00000042 [SR] Verify complete 2014-12-23 23:14:06, Info CSI 00000043 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:06, Info CSI 00000044 [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:11, Info CSI 00000045 [SR] Verify complete 2014-12-23 23:14:11, Info CSI 00000046 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:11, Info CSI 00000047 [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:17, Info CSI 00000048 [SR] Verify complete 2014-12-23 23:14:17, Info CSI 00000049 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:17, Info CSI 0000004a [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:22, Info CSI 0000004b [SR] Verify complete 2014-12-23 23:14:23, Info CSI 0000004c [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:23, Info CSI 0000004d [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:28, Info CSI 0000004e [SR] Verify complete 2014-12-23 23:14:28, Info CSI 0000004f [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:28, Info CSI 00000050 [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:34, Info CSI 00000051 [SR] Verify complete 2014-12-23 23:14:34, Info CSI 00000052 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:34, Info CSI 00000053 [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:39, Info CSI 00000054 [SR] Verify complete 2014-12-23 23:14:39, Info CSI 00000055 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:39, Info CSI 00000056 [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:44, Info CSI 00000057 [SR] Verify complete 2014-12-23 23:14:44, Info CSI 00000058 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:44, Info CSI 00000059 [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:49, Info CSI 0000005a [SR] Verify complete 2014-12-23 23:14:50, Info CSI 0000005b [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:50, Info CSI 0000005c [SR] Beginning Verify and Repair transaction 2014-12-23 23:14:56, Info CSI 0000005d [SR] Verify complete 2014-12-23 23:14:56, Info CSI 0000005e [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:14:56, Info CSI 0000005f [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:02, Info CSI 00000060 [SR] Verify complete 2014-12-23 23:15:02, Info CSI 00000061 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:02, Info CSI 00000062 [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:07, Info CSI 00000063 [SR] Verify complete 2014-12-23 23:15:08, Info CSI 00000064 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:08, Info CSI 00000065 [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:14, Info CSI 00000066 [SR] Verify complete 2014-12-23 23:15:14, Info CSI 00000067 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:14, Info CSI 00000068 [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:19, Info CSI 00000069 [SR] Verify complete 2014-12-23 23:15:19, Info CSI 0000006a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:19, Info CSI 0000006b [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:24, Info CSI 0000006c [SR] Verify complete 2014-12-23 23:15:24, Info CSI 0000006d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:24, Info CSI 0000006e [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:30, Info CSI 0000006f [SR] Verify complete 2014-12-23 23:15:30, Info CSI 00000070 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:30, Info CSI 00000071 [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:35, Info CSI 00000072 [SR] Verify complete 2014-12-23 23:15:35, Info CSI 00000073 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:35, Info CSI 00000074 [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:40, Info CSI 00000075 [SR] Verify complete 2014-12-23 23:15:40, Info CSI 00000076 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:40, Info CSI 00000077 [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:45, Info CSI 00000078 [SR] Verify complete 2014-12-23 23:15:45, Info CSI 00000079 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:45, Info CSI 0000007a [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:50, Info CSI 0000007b [SR] Verify complete 2014-12-23 23:15:50, Info CSI 0000007c [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:50, Info CSI 0000007d [SR] Beginning Verify and Repair transaction 2014-12-23 23:15:56, Info CSI 0000007e [SR] Verify complete 2014-12-23 23:15:56, Info CSI 0000007f [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:15:56, Info CSI 00000080 [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:01, Info CSI 00000081 [SR] Verify complete 2014-12-23 23:16:01, Info CSI 00000082 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:01, Info CSI 00000083 [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:06, Info CSI 00000084 [SR] Verify complete 2014-12-23 23:16:06, Info CSI 00000085 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:06, Info CSI 00000086 [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:12, Info CSI 00000087 [SR] Verify complete 2014-12-23 23:16:13, Info CSI 00000088 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:13, Info CSI 00000089 [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:18, Info CSI 0000008a [SR] Verify complete 2014-12-23 23:16:18, Info CSI 0000008b [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:18, Info CSI 0000008c [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:23, Info CSI 0000008d [SR] Verify complete 2014-12-23 23:16:23, Info CSI 0000008e [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:23, Info CSI 0000008f [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:30, Info CSI 00000090 [SR] Verify complete 2014-12-23 23:16:31, Info CSI 00000091 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:31, Info CSI 00000092 [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:37, Info CSI 00000093 [SR] Verify complete 2014-12-23 23:16:37, Info CSI 00000094 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:37, Info CSI 00000095 [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:43, Info CSI 00000096 [SR] Verify complete 2014-12-23 23:16:43, Info CSI 00000097 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:43, Info CSI 00000098 [SR] Beginning Verify and Repair transaction 2014-12-23 23:16:52, Info CSI 0000009c [SR] Verify complete 2014-12-23 23:16:52, Info CSI 0000009d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:16:52, Info CSI 0000009e [SR] Beginning Verify and Repair transaction 2014-12-23 23:17:00, Info CSI 000000b5 [SR] Verify complete 2014-12-23 23:17:01, Info CSI 000000b6 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:17:01, Info CSI 000000b7 [SR] Beginning Verify and Repair transaction 2014-12-23 23:17:13, Info CSI 000000be [SR] Verify complete 2014-12-23 23:17:13, Info CSI 000000bf [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:17:13, Info CSI 000000c0 [SR] Beginning Verify and Repair transaction 2014-12-23 23:17:22, Info CSI 000000c6 [SR] Verify complete 2014-12-23 23:17:22, Info CSI 000000c7 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:17:22, Info CSI 000000c8 [SR] Beginning Verify and Repair transaction 2014-12-23 23:17:32, Info CSI 000000d1 [SR] Verify complete 2014-12-23 23:17:33, Info CSI 000000d2 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:17:33, Info CSI 000000d3 [SR] Beginning Verify and Repair transaction 2014-12-23 23:17:42, Info CSI 000000d6 [SR] Verify complete 2014-12-23 23:17:42, Info CSI 000000d7 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:17:42, Info CSI 000000d8 [SR] Beginning Verify and Repair transaction 2014-12-23 23:17:49, Info CSI 000000d9 [SR] Verify complete 2014-12-23 23:17:49, Info CSI 000000da [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:17:49, Info CSI 000000db [SR] Beginning Verify and Repair transaction 2014-12-23 23:18:02, Info CSI 000000e2 [SR] Verify complete 2014-12-23 23:18:02, Info CSI 000000e3 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:18:02, Info CSI 000000e4 [SR] Beginning Verify and Repair transaction 2014-12-23 23:18:16, Info CSI 00000100 [SR] Verify complete 2014-12-23 23:18:17, Info CSI 00000101 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:18:17, Info CSI 00000102 [SR] Beginning Verify and Repair transaction 2014-12-23 23:18:29, Info CSI 00000126 [SR] Verify complete 2014-12-23 23:18:30, Info CSI 00000127 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:18:30, Info CSI 00000128 [SR] Beginning Verify and Repair transaction 2014-12-23 23:18:40, Info CSI 00000132 [SR] Verify complete 2014-12-23 23:18:41, Info CSI 00000133 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:18:41, Info CSI 00000134 [SR] Beginning Verify and Repair transaction 2014-12-23 23:18:53, Info CSI 0000013d [SR] Verify complete 2014-12-23 23:18:53, Info CSI 0000013e [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:18:53, Info CSI 0000013f [SR] Beginning Verify and Repair transaction 2014-12-23 23:19:05, Info CSI 00000155 [SR] Verify complete 2014-12-23 23:19:05, Info CSI 00000156 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:19:05, Info CSI 00000157 [SR] Beginning Verify and Repair transaction 2014-12-23 23:19:15, Info CSI 0000015f [SR] Verify complete 2014-12-23 23:19:15, Info CSI 00000160 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:19:15, Info CSI 00000161 [SR] Beginning Verify and Repair transaction 2014-12-23 23:19:25, Info CSI 00000162 [SR] Verify complete 2014-12-23 23:19:25, Info CSI 00000163 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:19:25, Info CSI 00000164 [SR] Beginning Verify and Repair transaction 2014-12-23 23:19:35, Info CSI 00000169 [SR] Verify complete 2014-12-23 23:19:36, Info CSI 0000016a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:19:36, Info CSI 0000016b [SR] Beginning Verify and Repair transaction 2014-12-23 23:19:46, Info CSI 00000170 [SR] Verify complete 2014-12-23 23:19:46, Info CSI 00000171 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:19:46, Info CSI 00000172 [SR] Beginning Verify and Repair transaction 2014-12-23 23:20:02, Info CSI 000001aa [SR] Verify complete 2014-12-23 23:20:03, Info CSI 000001ab [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:20:03, Info CSI 000001ac [SR] Beginning Verify and Repair transaction 2014-12-23 23:20:25, Info CSI 000001c1 [SR] Verify complete 2014-12-23 23:20:25, Info CSI 000001c2 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:20:25, Info CSI 000001c3 [SR] Beginning Verify and Repair transaction 2014-12-23 23:20:54, Info CSI 000001e3 [SR] Verify complete 2014-12-23 23:20:55, Info CSI 000001e4 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:20:55, Info CSI 000001e5 [SR] Beginning Verify and Repair transaction 2014-12-23 23:21:15, Info CSI 000001e6 [SR] Verify complete 2014-12-23 23:21:16, Info CSI 000001e7 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:21:16, Info CSI 000001e8 [SR] Beginning Verify and Repair transaction 2014-12-23 23:21:25, Info CSI 000001ef [SR] Verify complete 2014-12-23 23:21:25, Info CSI 000001f0 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:21:25, Info CSI 000001f1 [SR] Beginning Verify and Repair transaction 2014-12-23 23:21:33, Info CSI 000001fc [SR] Verify complete 2014-12-23 23:21:34, Info CSI 000001fd [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:21:34, Info CSI 000001fe [SR] Beginning Verify and Repair transaction 2014-12-23 23:21:48, Info CSI 00000219 [SR] Verify complete 2014-12-23 23:21:48, Info CSI 0000021a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:21:48, Info CSI 0000021b [SR] Beginning Verify and Repair transaction 2014-12-23 23:21:56, Info CSI 0000021d [SR] Verify complete 2014-12-23 23:21:56, Info CSI 0000021e [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:21:56, Info CSI 0000021f [SR] Beginning Verify and Repair transaction 2014-12-23 23:22:02, Info CSI 00000220 [SR] Verify complete 2014-12-23 23:22:02, Info CSI 00000221 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:22:02, Info CSI 00000222 [SR] Beginning Verify and Repair transaction 2014-12-23 23:22:13, Info CSI 0000022e [SR] Verify complete 2014-12-23 23:22:13, Info CSI 0000022f [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:22:13, Info CSI 00000230 [SR] Beginning Verify and Repair transaction 2014-12-23 23:22:23, Info CSI 00000270 [SR] Verify complete 2014-12-23 23:22:23, Info CSI 00000271 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:22:23, Info CSI 00000272 [SR] Beginning Verify and Repair transaction 2014-12-23 23:22:33, Info CSI 000002aa [SR] Verify complete 2014-12-23 23:22:34, Info CSI 000002ab [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:22:34, Info CSI 000002ac [SR] Beginning Verify and Repair transaction 2014-12-23 23:22:52, Info CSI 000002be [SR] Verify complete 2014-12-23 23:22:52, Info CSI 000002bf [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:22:52, Info CSI 000002c0 [SR] Beginning Verify and Repair transaction 2014-12-23 23:23:01, Info CSI 000002c4 [SR] Verify complete 2014-12-23 23:23:02, Info CSI 000002c5 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:23:02, Info CSI 000002c6 [SR] Beginning Verify and Repair transaction 2014-12-23 23:23:15, Info CSI 000002e1 [SR] Verify complete 2014-12-23 23:23:16, Info CSI 000002e2 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:23:16, Info CSI 000002e3 [SR] Beginning Verify and Repair transaction 2014-12-23 23:23:30, Info CSI 000002e8 [SR] Verify complete 2014-12-23 23:23:30, Info CSI 000002e9 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:23:30, Info CSI 000002ea [SR] Beginning Verify and Repair transaction 2014-12-23 23:23:45, Info CSI 000002f3 [SR] Verify complete 2014-12-23 23:23:45, Info CSI 000002f4 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:23:45, Info CSI 000002f5 [SR] Beginning Verify and Repair transaction 2014-12-23 23:23:54, Info CSI 000002f9 [SR] Verify complete 2014-12-23 23:23:55, Info CSI 000002fa [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:23:55, Info CSI 000002fb [SR] Beginning Verify and Repair transaction 2014-12-23 23:24:19, Info CSI 00000319 [SR] Verify complete 2014-12-23 23:24:19, Info CSI 0000031a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:24:19, Info CSI 0000031b [SR] Beginning Verify and Repair transaction 2014-12-23 23:24:29, Info CSI 00000322 [SR] Verify complete 2014-12-23 23:24:30, Info CSI 00000323 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:24:30, Info CSI 00000324 [SR] Beginning Verify and Repair transaction 2014-12-23 23:24:39, Info CSI 0000032a [SR] Verify complete 2014-12-23 23:24:39, Info CSI 0000032b [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:24:39, Info CSI 0000032c [SR] Beginning Verify and Repair transaction 2014-12-23 23:24:54, Info CSI 00000336 [SR] Verify complete 2014-12-23 23:24:55, Info CSI 00000337 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:24:55, Info CSI 00000338 [SR] Beginning Verify and Repair transaction 2014-12-23 23:25:08, Info CSI 00000366 [SR] Verify complete 2014-12-23 23:25:08, Info CSI 00000367 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:25:08, Info CSI 00000368 [SR] Beginning Verify and Repair transaction 2014-12-23 23:25:17, Info CSI 0000036a [SR] Verify complete 2014-12-23 23:25:17, Info CSI 0000036b [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:25:17, Info CSI 0000036c [SR] Beginning Verify and Repair transaction 2014-12-23 23:25:28, Info CSI 00000377 [SR] Verify complete 2014-12-23 23:25:28, Info CSI 00000378 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:25:28, Info CSI 00000379 [SR] Beginning Verify and Repair transaction 2014-12-23 23:25:37, Info CSI 0000038b [SR] Verify complete 2014-12-23 23:25:38, Info CSI 0000038c [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:25:38, Info CSI 0000038d [SR] Beginning Verify and Repair transaction 2014-12-23 23:25:56, Info CSI 00000393 [SR] Verify complete 2014-12-23 23:25:56, Info CSI 00000394 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:25:56, Info CSI 00000395 [SR] Beginning Verify and Repair transaction 2014-12-23 23:26:07, Info CSI 000003a1 [SR] Verify complete 2014-12-23 23:26:07, Info CSI 000003a2 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:26:07, Info CSI 000003a3 [SR] Beginning Verify and Repair transaction 2014-12-23 23:26:16, Info CSI 000003ac [SR] Verify complete 2014-12-23 23:26:16, Info CSI 000003ad [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:26:16, Info CSI 000003ae [SR] Beginning Verify and Repair transaction 2014-12-23 23:26:33, Info CSI 000003b3 [SR] Verify complete 2014-12-23 23:26:33, Info CSI 000003b4 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:26:33, Info CSI 000003b5 [SR] Beginning Verify and Repair transaction 2014-12-23 23:26:45, Info CSI 000003b7 [SR] Verify complete 2014-12-23 23:26:45, Info CSI 000003b8 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:26:45, Info CSI 000003b9 [SR] Beginning Verify and Repair transaction 2014-12-23 23:27:02, Info CSI 000003c0 [SR] Verify complete 2014-12-23 23:27:03, Info CSI 000003c1 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:27:03, Info CSI 000003c2 [SR] Beginning Verify and Repair transaction 2014-12-23 23:27:20, Info CSI 000003cf [SR] Verify complete 2014-12-23 23:27:20, Info CSI 000003d0 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:27:20, Info CSI 000003d1 [SR] Beginning Verify and Repair transaction 2014-12-23 23:27:33, Info CSI 000003d4 [SR] Verify complete 2014-12-23 23:27:33, Info CSI 000003d5 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:27:33, Info CSI 000003d6 [SR] Beginning Verify and Repair transaction 2014-12-23 23:27:43, Info CSI 000003d7 [SR] Verify complete 2014-12-23 23:27:43, Info CSI 000003d8 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:27:43, Info CSI 000003d9 [SR] Beginning Verify and Repair transaction 2014-12-23 23:28:46, Info CSI 000003e9 [SR] Verify complete 2014-12-23 23:28:47, Info CSI 000003ea [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:28:47, Info CSI 000003eb [SR] Beginning Verify and Repair transaction 2014-12-23 23:29:11, Info CSI 000003ee [SR] Verify complete 2014-12-23 23:29:11, Info CSI 000003ef [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:29:11, Info CSI 000003f0 [SR] Beginning Verify and Repair transaction 2014-12-23 23:29:32, Info CSI 000003fc [SR] Verify complete 2014-12-23 23:29:32, Info CSI 000003fd [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:29:32, Info CSI 000003fe [SR] Beginning Verify and Repair transaction 2014-12-23 23:29:51, Info CSI 0000042b [SR] Verify complete 2014-12-23 23:29:51, Info CSI 0000042c [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:29:51, Info CSI 0000042d [SR] Beginning Verify and Repair transaction 2014-12-23 23:30:22, Info CSI 00000434 [SR] Verify complete 2014-12-23 23:30:22, Info CSI 00000435 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:30:22, Info CSI 00000436 [SR] Beginning Verify and Repair transaction 2014-12-23 23:30:34, Info CSI 0000043d [SR] Verify complete 2014-12-23 23:30:34, Info CSI 0000043e [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:30:34, Info CSI 0000043f [SR] Beginning Verify and Repair transaction 2014-12-23 23:30:49, Info CSI 00000440 [SR] Verify complete 2014-12-23 23:30:49, Info CSI 00000441 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:30:49, Info CSI 00000442 [SR] Beginning Verify and Repair transaction 2014-12-23 23:31:01, Info CSI 00000443 [SR] Verify complete 2014-12-23 23:31:01, Info CSI 00000444 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:31:01, Info CSI 00000445 [SR] Beginning Verify and Repair transaction 2014-12-23 23:31:27, Info CSI 0000044b [SR] Verify complete 2014-12-23 23:31:27, Info CSI 0000044c [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:31:27, Info CSI 0000044d [SR] Beginning Verify and Repair transaction 2014-12-23 23:31:50, Info CSI 00000457 [SR] Verify complete 2014-12-23 23:31:50, Info CSI 00000458 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:31:50, Info CSI 00000459 [SR] Beginning Verify and Repair transaction 2014-12-23 23:32:04, Info CSI 00000466 [SR] Verify complete 2014-12-23 23:32:04, Info CSI 00000467 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:32:04, Info CSI 00000468 [SR] Beginning Verify and Repair transaction 2014-12-23 23:32:19, Info CSI 00000473 [SR] Verify complete 2014-12-23 23:32:19, Info CSI 00000474 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:32:19, Info CSI 00000475 [SR] Beginning Verify and Repair transaction 2014-12-23 23:32:30, Info CSI 0000047f [SR] Verify complete 2014-12-23 23:32:30, Info CSI 00000480 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:32:30, Info CSI 00000481 [SR] Beginning Verify and Repair transaction 2014-12-23 23:32:40, Info CSI 0000048f [SR] Verify complete 2014-12-23 23:32:40, Info CSI 00000490 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:32:40, Info CSI 00000491 [SR] Beginning Verify and Repair transaction 2014-12-23 23:32:53, Info CSI 00000493 [SR] Verify complete 2014-12-23 23:32:53, Info CSI 00000494 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:32:53, Info CSI 00000495 [SR] Beginning Verify and Repair transaction 2014-12-23 23:33:09, Info CSI 00000496 [SR] Verify complete 2014-12-23 23:33:09, Info CSI 00000497 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:33:09, Info CSI 00000498 [SR] Beginning Verify and Repair transaction 2014-12-23 23:33:24, Info CSI 000004a6 [SR] Verify complete 2014-12-23 23:33:25, Info CSI 000004a7 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:33:25, Info CSI 000004a8 [SR] Beginning Verify and Repair transaction 2014-12-23 23:33:37, Info CSI 000004d2 [SR] Verify complete 2014-12-23 23:33:38, Info CSI 000004d3 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:33:38, Info CSI 000004d4 [SR] Beginning Verify and Repair transaction 2014-12-23 23:33:47, Info CSI 000004e5 [SR] Verify complete 2014-12-23 23:33:47, Info CSI 000004e6 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:33:47, Info CSI 000004e7 [SR] Beginning Verify and Repair transaction 2014-12-23 23:33:57, Info CSI 000004e8 [SR] Verify complete 2014-12-23 23:33:58, Info CSI 000004e9 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:33:58, Info CSI 000004ea [SR] Beginning Verify and Repair transaction 2014-12-23 23:34:08, Info CSI 000004eb [SR] Verify complete 2014-12-23 23:34:08, Info CSI 000004ec [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:34:08, Info CSI 000004ed [SR] Beginning Verify and Repair transaction 2014-12-23 23:34:21, Info CSI 000004ef [SR] Verify complete 2014-12-23 23:34:22, Info CSI 000004f0 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:34:22, Info CSI 000004f1 [SR] Beginning Verify and Repair transaction 2014-12-23 23:34:32, Info CSI 000004f2 [SR] Verify complete 2014-12-23 23:34:32, Info CSI 000004f3 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:34:32, Info CSI 000004f4 [SR] Beginning Verify and Repair transaction 2014-12-23 23:34:44, Info CSI 000004f5 [SR] Verify complete 2014-12-23 23:34:44, Info CSI 000004f6 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:34:44, Info CSI 000004f7 [SR] Beginning Verify and Repair transaction 2014-12-23 23:34:51, Info CSI 000004f8 [SR] Verify complete 2014-12-23 23:34:51, Info CSI 000004f9 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:34:51, Info CSI 000004fa [SR] Beginning Verify and Repair transaction 2014-12-23 23:35:07, Info CSI 000004fb [SR] Verify complete 2014-12-23 23:35:08, Info CSI 000004fc [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:35:08, Info CSI 000004fd [SR] Beginning Verify and Repair transaction 2014-12-23 23:35:17, Info CSI 000004fe [SR] Verify complete 2014-12-23 23:35:17, Info CSI 000004ff [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:35:17, Info CSI 00000500 [SR] Beginning Verify and Repair transaction 2014-12-23 23:35:24, Info CSI 00000501 [SR] Verify complete 2014-12-23 23:35:25, Info CSI 00000502 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:35:25, Info CSI 00000503 [SR] Beginning Verify and Repair transaction 2014-12-23 23:35:34, Info CSI 00000504 [SR] Verify complete 2014-12-23 23:35:34, Info CSI 00000505 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:35:34, Info CSI 00000506 [SR] Beginning Verify and Repair transaction 2014-12-23 23:35:42, Info CSI 00000523 [SR] Verify complete 2014-12-23 23:35:42, Info CSI 00000524 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:35:42, Info CSI 00000525 [SR] Beginning Verify and Repair transaction 2014-12-23 23:35:50, Info CSI 00000526 [SR] Verify complete 2014-12-23 23:35:50, Info CSI 00000527 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:35:50, Info CSI 00000528 [SR] Beginning Verify and Repair transaction 2014-12-23 23:35:58, Info CSI 0000052a [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch 2014-12-23 23:36:02, Info CSI 0000052c [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch 2014-12-23 23:36:02, Info CSI 0000052d [SR] This component was referenced by [l:186{93}]"Microsoft-Windows-Printer-Drivers-Package~31bf3856ad364e35~amd64~~6.3.9600.16384.INF_prncacla" 2014-12-23 23:36:08, Info CSI 00000530 [SR] Verify complete 2014-12-23 23:36:08, Info CSI 00000531 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:36:08, Info CSI 00000532 [SR] Beginning Verify and Repair transaction 2014-12-23 23:36:23, Info CSI 00000533 [SR] Verify complete 2014-12-23 23:36:23, Info CSI 00000534 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:36:23, Info CSI 00000535 [SR] Beginning Verify and Repair transaction 2014-12-23 23:36:37, Info CSI 00000536 [SR] Verify complete 2014-12-23 23:36:37, Info CSI 00000537 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:36:37, Info CSI 00000538 [SR] Beginning Verify and Repair transaction 2014-12-23 23:36:44, Info CSI 00000539 [SR] Verify complete 2014-12-23 23:36:44, Info CSI 0000053a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:36:44, Info CSI 0000053b [SR] Beginning Verify and Repair transaction 2014-12-23 23:36:55, Info CSI 0000053c [SR] Verify complete 2014-12-23 23:36:55, Info CSI 0000053d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:36:55, Info CSI 0000053e [SR] Beginning Verify and Repair transaction 2014-12-23 23:37:09, Info CSI 00000549 [SR] Verify complete 2014-12-23 23:37:09, Info CSI 0000054a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:37:09, Info CSI 0000054b [SR] Beginning Verify and Repair transaction 2014-12-23 23:37:16, Info CSI 0000054c [SR] Verify complete 2014-12-23 23:37:17, Info CSI 0000054d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:37:17, Info CSI 0000054e [SR] Beginning Verify and Repair transaction 2014-12-23 23:37:23, Info CSI 0000054f [SR] Verify complete 2014-12-23 23:37:23, Info CSI 00000550 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:37:23, Info CSI 00000551 [SR] Beginning Verify and Repair transaction 2014-12-23 23:37:32, Info CSI 000005bf [SR] Verify complete 2014-12-23 23:37:32, Info CSI 000005c0 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:37:32, Info CSI 000005c1 [SR] Beginning Verify and Repair transaction 2014-12-23 23:37:39, Info CSI 000005c4 [SR] Verify complete 2014-12-23 23:37:39, Info CSI 000005c5 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:37:39, Info CSI 000005c6 [SR] Beginning Verify and Repair transaction 2014-12-23 23:37:46, Info CSI 000005c7 [SR] Verify complete 2014-12-23 23:37:47, Info CSI 000005c8 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:37:47, Info CSI 000005c9 [SR] Beginning Verify and Repair transaction 2014-12-23 23:37:54, Info CSI 000005ca [SR] Verify complete 2014-12-23 23:37:54, Info CSI 000005cb [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:37:54, Info CSI 000005cc [SR] Beginning Verify and Repair transaction 2014-12-23 23:38:01, Info CSI 000005cd [SR] Verify complete 2014-12-23 23:38:01, Info CSI 000005ce [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:38:01, Info CSI 000005cf [SR] Beginning Verify and Repair transaction 2014-12-23 23:38:09, Info CSI 000005d0 [SR] Verify complete 2014-12-23 23:38:09, Info CSI 000005d1 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:38:09, Info CSI 000005d2 [SR] Beginning Verify and Repair transaction 2014-12-23 23:38:18, Info CSI 000005de [SR] Verify complete 2014-12-23 23:38:18, Info CSI 000005df [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:38:18, Info CSI 000005e0 [SR] Beginning Verify and Repair transaction 2014-12-23 23:38:27, Info CSI 000005f9 [SR] Verify complete 2014-12-23 23:38:28, Info CSI 000005fa [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:38:28, Info CSI 000005fb [SR] Beginning Verify and Repair transaction 2014-12-23 23:38:38, Info CSI 0000060c [SR] Verify complete 2014-12-23 23:38:39, Info CSI 0000060d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:38:39, Info CSI 0000060e [SR] Beginning Verify and Repair transaction 2014-12-23 23:38:49, Info CSI 00000610 [SR] Verify complete 2014-12-23 23:38:49, Info CSI 00000611 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:38:49, Info CSI 00000612 [SR] Beginning Verify and Repair transaction 2014-12-23 23:38:55, Info CSI 00000613 [SR] Verify complete 2014-12-23 23:38:55, Info CSI 00000614 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:38:55, Info CSI 00000615 [SR] Beginning Verify and Repair transaction 2014-12-23 23:39:02, Info CSI 00000619 [SR] Verify complete 2014-12-23 23:39:03, Info CSI 0000061a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:39:03, Info CSI 0000061b [SR] Beginning Verify and Repair transaction 2014-12-23 23:39:17, Info CSI 00000626 [SR] Verify complete 2014-12-23 23:39:17, Info CSI 00000627 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:39:17, Info CSI 00000628 [SR] Beginning Verify and Repair transaction 2014-12-23 23:39:28, Info CSI 0000063f [SR] Verify complete 2014-12-23 23:39:29, Info CSI 00000640 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:39:29, Info CSI 00000641 [SR] Beginning Verify and Repair transaction 2014-12-23 23:39:37, Info CSI 0000064f [SR] Verify complete 2014-12-23 23:39:38, Info CSI 00000650 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:39:38, Info CSI 00000651 [SR] Beginning Verify and Repair transaction 2014-12-23 23:39:50, Info CSI 0000065b [SR] Verify complete 2014-12-23 23:39:50, Info CSI 0000065c [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:39:50, Info CSI 0000065d [SR] Beginning Verify and Repair transaction 2014-12-23 23:40:08, Info CSI 00000676 [SR] Verify complete 2014-12-23 23:40:08, Info CSI 00000677 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:40:08, Info CSI 00000678 [SR] Beginning Verify and Repair transaction 2014-12-23 23:40:20, Info CSI 0000068f [SR] Verify complete 2014-12-23 23:40:21, Info CSI 00000690 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:40:21, Info CSI 00000691 [SR] Beginning Verify and Repair transaction 2014-12-23 23:40:34, Info CSI 000006d6 [SR] Verify complete 2014-12-23 23:40:34, Info CSI 000006d7 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:40:34, Info CSI 000006d8 [SR] Beginning Verify and Repair transaction 2014-12-23 23:40:43, Info CSI 000006d9 [SR] Verify complete 2014-12-23 23:40:43, Info CSI 000006da [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:40:43, Info CSI 000006db [SR] Beginning Verify and Repair transaction 2014-12-23 23:40:51, Info CSI 000006de [SR] Verify complete 2014-12-23 23:40:51, Info CSI 000006df [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:40:51, Info CSI 000006e0 [SR] Beginning Verify and Repair transaction 2014-12-23 23:41:02, Info CSI 000006fa [SR] Verify complete 2014-12-23 23:41:02, Info CSI 000006fb [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:41:02, Info CSI 000006fc [SR] Beginning Verify and Repair transaction 2014-12-23 23:41:13, Info CSI 0000070f [SR] Verify complete 2014-12-23 23:41:13, Info CSI 00000710 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:41:13, Info CSI 00000711 [SR] Beginning Verify and Repair transaction 2014-12-23 23:41:23, Info CSI 00000727 [SR] Verify complete 2014-12-23 23:41:23, Info CSI 00000728 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:41:23, Info CSI 00000729 [SR] Beginning Verify and Repair transaction 2014-12-23 23:41:32, Info CSI 00000731 [SR] Verify complete 2014-12-23 23:41:32, Info CSI 00000732 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:41:32, Info CSI 00000733 [SR] Beginning Verify and Repair transaction 2014-12-23 23:41:41, Info CSI 00000734 [SR] Verify complete 2014-12-23 23:41:41, Info CSI 00000735 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:41:41, Info CSI 00000736 [SR] Beginning Verify and Repair transaction 2014-12-23 23:41:52, Info CSI 00000739 [SR] Verify complete 2014-12-23 23:41:53, Info CSI 0000073a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:41:53, Info CSI 0000073b [SR] Beginning Verify and Repair transaction 2014-12-23 23:42:06, Info CSI 00000763 [SR] Verify complete 2014-12-23 23:42:07, Info CSI 00000764 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:42:07, Info CSI 00000765 [SR] Beginning Verify and Repair transaction 2014-12-23 23:42:14, Info CSI 00000767 [SR] Verify complete 2014-12-23 23:42:14, Info CSI 00000768 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:42:14, Info CSI 00000769 [SR] Beginning Verify and Repair transaction 2014-12-23 23:42:26, Info CSI 00000780 [SR] Verify complete 2014-12-23 23:42:26, Info CSI 00000781 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:42:26, Info CSI 00000782 [SR] Beginning Verify and Repair transaction 2014-12-23 23:42:31, Info CSI 00000783 [SR] Verify complete 2014-12-23 23:42:32, Info CSI 00000784 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:42:32, Info CSI 00000785 [SR] Beginning Verify and Repair transaction 2014-12-23 23:42:44, Info CSI 0000078e [SR] Verify complete 2014-12-23 23:42:44, Info CSI 0000078f [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:42:44, Info CSI 00000790 [SR] Beginning Verify and Repair transaction 2014-12-23 23:42:55, Info CSI 000007aa [SR] Verify complete 2014-12-23 23:42:55, Info CSI 000007ab [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:42:55, Info CSI 000007ac [SR] Beginning Verify and Repair transaction 2014-12-23 23:43:05, Info CSI 000007ae [SR] Verify complete 2014-12-23 23:43:05, Info CSI 000007af [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:43:05, Info CSI 000007b0 [SR] Beginning Verify and Repair transaction 2014-12-23 23:43:13, Info CSI 000007b4 [SR] Verify complete 2014-12-23 23:43:13, Info CSI 000007b5 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:43:13, Info CSI 000007b6 [SR] Beginning Verify and Repair transaction 2014-12-23 23:43:32, Info CSI 000007d7 [SR] Verify complete 2014-12-23 23:43:32, Info CSI 000007d8 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:43:32, Info CSI 000007d9 [SR] Beginning Verify and Repair transaction 2014-12-23 23:43:41, Info CSI 000007df [SR] Verify complete 2014-12-23 23:43:41, Info CSI 000007e0 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:43:41, Info CSI 000007e1 [SR] Beginning Verify and Repair transaction 2014-12-23 23:44:03, Info CSI 0000080c [SR] Verify complete 2014-12-23 23:44:03, Info CSI 0000080d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:44:03, Info CSI 0000080e [SR] Beginning Verify and Repair transaction 2014-12-23 23:44:10, Info CSI 0000080f [SR] Verify complete 2014-12-23 23:44:11, Info CSI 00000810 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:44:11, Info CSI 00000811 [SR] Beginning Verify and Repair transaction 2014-12-23 23:44:19, Info CSI 00000822 [SR] Verify complete 2014-12-23 23:44:20, Info CSI 00000823 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:44:20, Info CSI 00000824 [SR] Beginning Verify and Repair transaction 2014-12-23 23:44:28, Info CSI 00000826 [SR] Verify complete 2014-12-23 23:44:28, Info CSI 00000827 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:44:28, Info CSI 00000828 [SR] Beginning Verify and Repair transaction 2014-12-23 23:44:38, Info CSI 0000082d [SR] Verify complete 2014-12-23 23:44:39, Info CSI 0000082e [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:44:39, Info CSI 0000082f [SR] Beginning Verify and Repair transaction 2014-12-23 23:44:48, Info CSI 00000832 [SR] Verify complete 2014-12-23 23:44:48, Info CSI 00000833 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:44:48, Info CSI 00000834 [SR] Beginning Verify and Repair transaction 2014-12-23 23:44:57, Info CSI 00000839 [SR] Verify complete 2014-12-23 23:44:57, Info CSI 0000083a [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:44:57, Info CSI 0000083b [SR] Beginning Verify and Repair transaction 2014-12-23 23:45:06, Info CSI 00000840 [SR] Verify complete 2014-12-23 23:45:06, Info CSI 00000841 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:45:06, Info CSI 00000842 [SR] Beginning Verify and Repair transaction 2014-12-23 23:45:14, Info CSI 00000845 [SR] Verify complete 2014-12-23 23:45:14, Info CSI 00000846 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:45:14, Info CSI 00000847 [SR] Beginning Verify and Repair transaction 2014-12-23 23:45:21, Info CSI 0000084c [SR] Verify complete 2014-12-23 23:45:22, Info CSI 0000084d [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:45:22, Info CSI 0000084e [SR] Beginning Verify and Repair transaction 2014-12-23 23:45:30, Info CSI 00000850 [SR] Verify complete 2014-12-23 23:45:31, Info CSI 00000851 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:45:31, Info CSI 00000852 [SR] Beginning Verify and Repair transaction 2014-12-23 23:45:39, Info CSI 00000854 [SR] Verify complete 2014-12-23 23:45:39, Info CSI 00000855 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:45:39, Info CSI 00000856 [SR] Beginning Verify and Repair transaction 2014-12-23 23:45:50, Info CSI 00000861 [SR] Verify complete 2014-12-23 23:45:50, Info CSI 00000862 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:45:50, Info CSI 00000863 [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:00, Info CSI 00000864 [SR] Verify complete 2014-12-23 23:46:00, Info CSI 00000865 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:46:00, Info CSI 00000866 [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:11, Info CSI 00000868 [SR] Verify complete 2014-12-23 23:46:11, Info CSI 00000869 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:46:11, Info CSI 0000086a [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:19, Info CSI 0000086b [SR] Verify complete 2014-12-23 23:46:19, Info CSI 0000086c [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:46:19, Info CSI 0000086d [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:30, Info CSI 0000086e [SR] Verify complete 2014-12-23 23:46:30, Info CSI 0000086f [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:46:30, Info CSI 00000870 [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:37, Info CSI 00000871 [SR] Verify complete 2014-12-23 23:46:37, Info CSI 00000872 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:46:37, Info CSI 00000873 [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:47, Info CSI 00000874 [SR] Verify complete 2014-12-23 23:46:47, Info CSI 00000875 [SR] Verifying 100 (0x0000000000000064) components 2014-12-23 23:46:47, Info CSI 00000876 [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:57, Info CSI 00000879 [SR] Verify complete 2014-12-23 23:46:57, Info CSI 0000087a [SR] Verifying 20 (0x0000000000000014) components 2014-12-23 23:46:57, Info CSI 0000087b [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:58, Info CSI 0000087c [SR] Verify complete 2014-12-23 23:46:58, Info CSI 0000087d [SR] Repairing 1 components 2014-12-23 23:46:58, Info CSI 0000087e [SR] Beginning Verify and Repair transaction 2014-12-23 23:46:59, Info CSI 00000880 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch 2014-12-23 23:46:59, Info CSI 00000882 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch 2014-12-23 23:46:59, Info CSI 00000883 [SR] This component was referenced by [l:186{93}]"Microsoft-Windows-Printer-Drivers-Package~31bf3856ad364e35~amd64~~6.3.9600.16384.INF_prncacla" 2014-12-23 23:47:00, Info CSI 00000884 [SR] Repair complete 2014-12-23 23:47:00, Info CSI 00000885 [SR] Committing transaction 2014-12-23 23:47:00, Info CSI 0000088a [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired Link to comment Share on other sites More sharing options...
xilolee Posted December 24, 2014 Report Share Posted December 24, 2014 To solve the sfc problem, launch the following command (from an elevated command prompt): dism /online /cleanup-image /restorehealthAnyway, this won't repair your principal problem (at least, I don't think so... But you can check it anyway). Link to comment Share on other sites More sharing options...
