JieRu Posted December 20, 2014 Report Share Posted December 20, 2014 地區與語言的 系統地區設定原本是在中文 後來因為某種原因 改到了日文 後來要改回來 選擇了中文 並沒有出現重新開機的介面 反而畫面卡在那裏 連滑鼠也不能動 translated from chinese Region and language can not be set System Area region and language setting originally in Chinese for some reason later changed to the Japanese To change back later chose not to re-boot the Chinese interface screen appears instead stuck there Even the mouse not move Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:Windows Available physical memory: 6126 MB CPU: Intel® Core i5-2300 CPU @ 2.80GHz Drive Info: C: 456.49 GB D: 456.49 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted December 22, 2014 Report Share Posted December 22, 2014 Note: make the following things (that generate logs) using the english Language (because I can't read chinese logs ).Download and run System Update Readiness Tool for Windows 7 for x64-based Systems (KB947821) [May 2014] From an elevated command prompt, launch (Windows installation cd could be necessary): sfc /scannow Wait till it finishes (15-50 minutes).If the final result is equal to Windows Resource Protection did not find any integrity violations or equal to Windows Resource Protection found corrupt files and successfully repaired them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch this command: copy %SYSTEMROOT%\Logs\CBS\CheckSUR.log %userprofile%\desktop\CheckSUR.txt After it, you should find checkSUR.txt on your desktop: post it here.Instead if the final result of the SFC TOOL is equal to Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch both the previous command in the code above AND also this command: copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt && findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txt After those two commands, you should find three files on your desktop: checkSUR.txt, cbs.txt and SR.txt: post here the checkSUR.txt and the sr.txt.If the last command won't work, try these (one by one): copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txt How to run an elevated command prompt for Windows vista/seven usersOne of these three methods:- click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear- click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear- click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear Link to comment Share on other sites More sharing options...
