Posted
Bonjour, comme le montre le visuel joint, celui-ci ne veut plus afficher les vignettes des vidéos. Puis-je réparer le problème, si solution existe ?! Merci.
translated from french
File Explorer
Hello, as the visual seal shows, it does not want to view thumbnails of videos. Can I fix the problem if a solution exists! thank you
Operating system:Windows 8.1 Pro (64 bit)
System root: C:WINDOWS
Available physical memory: 3954 MB
CPU: Intel® Core i5-3230M CPU @ 2.60GHz
C: 297,55 GB
D: 150,64 GB
E: 931,51 GB
Internet Explorer: 11.0
Posted
1) Control Panel\System and Security\System, advanced system settings, click settings... under the performance frame, tick show thumbnails instead of icons, click ok
2) If the previous point won't work, open notepad, copy the following lines of code, save the file as reset-icon.bat, right-click the new file, click run as administrator.
The system will be restarted, hence save your work and close every working program/application before you run this batch.
@echo off
taskkill /im explorer.exe /f
pause
attrib -h -r -s "%localappdata%\iconcache.db"
del "%localappdata%\iconcache.db"
del "%localappdata%\Microsoft\Windows\Explorer\icon*.db"
del "%localappdata%\Microsoft\Windows\Explorer\thumb*.db"
echo.
echo.
echo The system is going to restart
echo.
echo.
pause
shutdown /f /t 0 /r
3) If the previous point won't work, go to sevenforums - Default File Type Associations - Restore (click), download the avi registry file and the other extensions that you need, import it/them (double-left-click the file and add it to your registry).
Later, right-click your video, open with, choose default program..., tick use this application for all .avi files, click your preferred media player.
Repeat for your other extensions.
Looking forward for your kind feedback.
