nicehumor Posted November 12, 2014 Report Share Posted November 12, 2014 右键点击‘计算机’-‘管理’,提示:“该文件没有与之关联的程序来执行操作。请安装一个程序,或者,如果已安装程序,请在“默认程序”控制面板中创建关联。 translated from chinese Right-click on the Computer - Manage Failure Right-click 'Computer' - 'management', prompt: "This file does not have a program associated with it to perform the operation, install a program, or if you have installed the program, please." Create an association Default Programs "control panel. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted November 18, 2014 Report Share Posted November 18, 2014 Try opening Computer Management from Start Search Bar. Follow the location to open computer management.1. Click on Start2. In the Start Search bar type Computer Management and hit enter and check if you are able to open it.Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.2. Type the following command, and then press ENTER:sfc /scannow3. The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. [source from Microsoft Community] Link to comment Share on other sites More sharing options...
