Posted
internet explorer window opens with small window often instead of full window. also start time is slow.
System root: C:Windows
Available physical memory: 1643 MB
CPU: AMD C-50 Processor
C: 218.92 GB
D: 13.67 GB
Internet Explorer: 11.0
Posted
Start time of what? Windows or internet Explorer?
1) maximize the MSIE11 Windows (i.e., click the maximise button in the upper-right corner), click the X button in the upper-right corner
2) maximize the MSIE11 Windows (i.e., click the maximise button in the upper-right corner), click the file menu, click exit
3) click start, type in the searchbox C:\Program Files (x86)\Internet Explorer, press enter, right-click iexplore.exe in the just opened window, click send to, click desktop, right-click the new MSIE shortcut, click properties, near the Run: line, choose maximised, click ok.
Or modify your already existing shortcut.
4) move the MSIE window so that the upper left corner of it matches that of the screen, go to the bottom-right corner of the MSIE window and enlarge the window whenever it matches that of the screen, click the file menu, click exit
5) if the previous didn't work, press CTRL key on your keyboard and keep it pressed just before clicking exit
6) if the previous didn't work, press SHIFT key on your keyboard and keep it pressed just before clicking exit
7) check raymond.cc - Maximize New Internet Explorer Windows
