montalbano Posted October 16, 2014 Report Share Posted October 16, 2014 L'audio non funziona più,applicando "soluzione problemi" esce il messaggio ( problema non risolto uno o più servizi audio non sono in esecuzione) Come devo fare per risolvere il problema? Operating system:Windows 8.1 (64 bit) System root: C:WINDOWS Available physical memory: 3988 MB CPU: Intel® Core i3-3217U CPU @ 1.80GHz Drive Info: C: 444,57 GB D: 20,08 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted October 20, 2014 Report Share Posted October 20, 2014 L'audio non funziona più,applicando "soluzione problemi" esce il messaggio ( problema non risolto uno o più servizi audio non sono in esecuzione)Come devo fare per risolvere il problema? English: The audio does not work anymore, applying "Problem Solving" comes the message (problem not solved one or more audio service is not running) How do I solve the problem? 1, Check your speaker, make sure it is working well. 2, Make sure you have installed the latest sound card driver. 3, Make sure you have select correct Playback device. 4, Make sure you don't set media players in mute mode. Link to comment Share on other sites More sharing options...
