said Posted October 3, 2014 Report Share Posted October 3, 2014 car sa configurtion cote-a-cote est incorrect. screenshot c:\program files(x86)\ibm\spss\statistics\22\stats.exe Application n'a pas pu démarrer car sa configuration cote-a-cote est incorrect. Pour plus d'informations, consultez le journal d'evenements d'applications ou utilisez l'outil de ligne de commande sxstrace.exe translated c:\program files(x86)\ibm\spss\statistics\22\stats.exe application failed to start because its configuration side-by-side is incorrect. For more information, see the Application event log or use the tool command line sxstrace.exe possible english message c:\program files(x86)\ibm\spss\statistics\22\stats.exe The application has failed to start because its side by side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail. Operating system:Windows 7 Home Premium (64 bit) System root: C:Windows Available physical memory: 3958 MB CPU: Intel® Core i3 CPU M 330 @ 2.13GHz Drive Info: C: 129,43 GB D: 103,45 GB E: 232,49 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
xilolee Posted October 6, 2014 Report Share Posted October 6, 2014 IBM SPSS Statistics Desktop 22.0.0.0 shows all Windows 7 versions with service pack 1 in its system requirements. Hence, you should install the service pack 1. Link to comment Share on other sites More sharing options...
