Saif.x5 Posted September 26, 2014 Report Share Posted September 26, 2014 لا اتسطيع مشاهدة صور نسق ايرو ولا حتى استطيع استعمال النسق translated from arabicPhotos aero formatI can not see the pictures of Aero format I can not even use the Layout Operating system:Windows 7 Ultimate (32 bit)System root: C:WindowsAvailable physical memory: 2012 MBCPU: Intel® Core2 Duo CPU T6570 @ 2.10GHzDrive Info:C: 115.60 GBD: 117.19 GBInternet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted September 27, 2014 Report Share Posted September 27, 2014 1) Delete CBS.log inside C:\Windows\Logs\CBS 2) Note: windows installation/repair cd could be necessary. Launch sfc /scannow from an elevated command prompt, wait until it finishes (15-50 minutes), check the final result (note it down). If it says no integrity violations (or something similar), stop here... Otherwise restart your machine and relaunch the tool. Then, report both final results here. 3) If both results says that there are damaged files and it can not restore them, post here the CBS.log file (upload it using the forum feature or a website where you could upload files). Link to comment Share on other sites More sharing options...
