ASAVIA Posted September 10, 2014 Report Share Posted September 10, 2014 При установке программы Punto Switcher вылетает ошибка 2203 screenshot установка - Punto Switcher 3.3.1 программа установки обнаружила непредвиденную ошибку при установке данного пакета. Возможно, она вызвана неполадками в этом пакете. Код ошибки 2203. translated from russian error 2203 When you install the program Punto Switcher crash bug 2203 screenshot installation - Punto Switcher 3.3.1 The setup has encountered an unexpected error installing this package. Perhaps it is caused by malfunctions in the package. Error Code 2203. possible english error message Punto Switcher 3.3.1 The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2203. Operating system:Windows 8.1 Pro (64 bit) System root: C:\Windows Available physical memory: 3949 MB CPU: Intel® Core i3 CPU M 350 @ 2.27GHz Drive Info: C: 80,50 GB E: 140,21 GB F: 77,38 GB Internet Explorer: 11.0 Milkafar and VerkaLymn 2 Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 Go to Control Panel\System and Security\System, click advanced system settings, click advanced tab, click environment variables and check if you have the following user variables (first panel): TEMP: %USERPROFILE%\AppData\Local\Temp TMP: %USERPROFILE%\AppData\Local\TempAnd the following system variables (second panel): TEMP: %SystemRoot%\TEMP TMP: %SystemRoot%\TEMPIf you don't have them, add them. Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 Personal message from ASAVIA Спасибо, но проблему не решил. Thanks, but the problem has not solved. Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 Go to %USERPROFILE%\AppData\Local (Windows folder), right-click the temp folder, click properties, click security tab, check if system has got full permissions: Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 Personal message from ASAVIA (you can reply here in this topic): система имеет полные права,но не помогло system has full rights, but did not help Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 Are you currently logged in your system as an administrator or as a standard account? Are you running the installer as an administrator? Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 Personal message from ASAVIA (you can reply here in this topic): вход как администратор и установщик с правами администратора login as an administrator and the installer as administrator Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 Google can't translate http://help.yandex.ru/punto-win/about/faq.xml You can probably ask for support for this program at [email protected] Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 Personal message from ASAVIA (you can reply here in this topic): спасибо за советы !!! thanks for the tips !!! Link to comment Share on other sites More sharing options...
xilolee Posted September 10, 2014 Report Share Posted September 10, 2014 You are welcome! Link to comment Share on other sites More sharing options...
