Posted
اتت لى هذه المشكله وانا اقول بتثبيت هذا البرنامج ولا يقوم بالتثبيت وانا احتاج هذا البرنامج
Translated from arab
You are my problem and I'll tell you install this program is not doing the installation, and I need this program
Operating system:Windows 8.1 Pro (64 bit)
System root: C:\WINDOWS
Available physical memory: 3982 MB
CPU: Intel® Core i3-3217U CPU @ 1.80GHz
C: 185.87 GB
D: 258.44 GB
Internet Explorer: 11.0
Posted
1) Delete CBS.log inside C:\Windows\Logs\CBS
2) Note: windows installation/repair cd could be necessary.
Launch sfc /scannow from an elevated command prompt, wait until it finishes (15-50 minutes), check the final result (note it down).
If it says no integrity violations (or something similar), stop here... Otherwise restart your machine and relaunch the tool. Then, report both final results here.
3) If both results says that there are damaged files and it can not restore them, post here the CBS.log file (upload it using the forum feature or a website where you could upload files).
Posted
I'll try to be simplier:
1) Open an elevated command prompt: right-click on Windows 8.1 start, click command prompt (admin)
2) In the black screen that appears, type sfc /scannow (and press enter on your keyboard).
3) Wait until it finishes (15-50 minutes)
4) Check the final result (note it down).
5) If it says no integrity violations (or something similar), stop here and skip all the following points
6) Otherwise (integrity violations found) restart your machine and relaunch the tool (re-read point 1, 2, 3, 4).
7) Then, report both final results here.
8) If both results says that there are damaged files and it can not restore them, post here the CBS.log file, that should be inside C:\Windows\Logs\CBS.
You can upload it here using the forum feature or you can use a website where you could upload files, like as an example speedyshare.com.
