Posted
I've been running Wise Care 365 Pro for a while and have ignored any messages about cleaning up my system. This morning I blindly decided to let the program run thinking I'd have a change to preview the changes. Not so, It ran automatically and deleted a bunch of stuff, some of which it shouldn't have. Twice today I've had a BSOD. I can't remember the last time I had a BSOD on this pc.
Is there a way to preview changes before giving final approval to proceed?
Is there a way to undo the "Fixes" that were made this morning?
Thanks
Posted
You can preview changes if you use every section on its own.
PC checkup will clean your pc in a click only (well, two clicks).
To undo the fixes, I think you can only use the most recent Windows restore point.
Posted
For example, from system cleaner --- common cleaner section, after the scan is terminated you can export every path to a log file with right-click on a casual element/item, export to.
The same applies to registry cleaner and advanced cleaner sections. ;)
(I would have preferred this had been done automatically, BTW)
