desperate Posted August 30, 2014 Report Share Posted August 30, 2014 電腦突然黑屏開不了機 強制關機後就進入藍屏錯誤代碼116 電腦又自動重新開機 只能進入安全模式 修復無效 系統還原無效 上網查了解決方式後把顯示卡中的AMD Radeon HD 6400M Series停用才能開機 之前試著解除安裝過可是電腦又會自動安裝 現在停用是可以開機但不穩定 而且畫面感覺變得比較長 速度變得很慢 是否應該要安裝其他的驅動程式? 本機型號:MS-1482 translated from chineseBlue screen error code 116Computer suddenly black screen can not be switched off after a forced error code 116 into the blue screen and automatically re-boot the computer into safe mode only fix invalid system restore invalid after the Internet search solution to display the card AMD Radeon HD 6400M Series disabled to boot but before you try to uninstall through the computer will automatically install the boot but can be disabled now feels unstable and the picture becomes longer very slowly, should you want to install other drivers the machine model:? MS-1482 Operating system:Windows 7 Home Premium (64 bit) Service Pack 1System root: C:\WindowsAvailable physical memory: 4003 MBCPU: Intel® Core i3-2310M CPU @ 2.10GHzDrive Info:C: 150.09 GBG: 147.99 GBInternet Explorer: 11.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 5, 2014 Report Share Posted September 5, 2014 Reinstall the video card driver. Link to comment Share on other sites More sharing options...
