maher Posted August 13, 2014 Report Share Posted August 13, 2014 رسالة خطأ نظام عند تشغيل بعض البرامج و translated from arabSystem ErrorSystem error message when running some programs and Operating system:Microsoft Windows XP (32 bit) Service Pack 3System root: C:\WINDOWSAvailable physical memory: 3071 MBCPU: Intel® Celeron® D CPU 3.06GHzDrive Info:C: 29.28 GBD: 39.06 GBE: 39.06 GBF: 43.43 GBG: 39.06 GBH: 39.06 GBI: 31.86 GBInternet Explorer: 6.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 13, 2014 Report Share Posted August 13, 2014 MOM.exe is a part of AMD Catalyst Control Center 1, You can reinstall your video card driver to fix it. (maybe you need to reinstall/update .NET Framework) 2, Or, you can disable AMD Catalyst Control Center, and it won't affect the video card driver. click Start->Run->type msconfig.exe then press Enter->Startup->deselect AMD Catalyst Control Center, then click OK to save settings. Link to comment Share on other sites More sharing options...
