denemedeneme Posted May 19, 2014 Report Share Posted May 19, 2014 bak işte Operating system:Windows 7 Ultimate (32 bit) System root: C:\Windows Available physical memory: 2037 MB CPU: Intel® Pentium® Dual CPU E2200 @ 2.20GHz Drive Info: C: 78,13 GB D: 70,92 GB Internet Explorer: 8.0 dywtnuec 1 Link to comment Share on other sites More sharing options...
xilolee Posted May 19, 2014 Report Share Posted May 19, 2014 error message: kayit defteri düzenleyicisi - the registry editor kayıt defteri düzenleme yöneticiniz tarafından devreden çıkarılmış - deactivated by editing the registry administrator error in english: registry editor registry editing has been disabled by your administrator 1) Have you already used the solution proposed by wise pc 1st aid about that problem? 2) Have you already tried to use gpedit.msc? - Windows key + R key opens the run window, type gpedit.msc, press enter - go to User Configuration --> Administrative Templates --> System, in the right pane select Prevent access to registry editing Tools and set it to Not configured or Disabled. 3) Have you already tried the other tools listed in techdows.com - 7 Ways to Fix ”Registry editing has been disabled by Your administrator “ (click) ? Link to comment Share on other sites More sharing options...
