tercan Posted April 27, 2014 Report Share Posted April 27, 2014 win8 kullanıyorum başlangıçta 2 işletim gösteriyor 1-win8 2-win loader exe nasıl düzeltebilirim Operating system:Windows 8 Pro (64 bit) System root: C:\Windows Available physical memory: 4053 MB CPU: Intel® Core i3-2120 CPU @ 3.30GHz Drive Info: C: 98,23 GB F: 367,19 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
云淡风轻 Posted April 28, 2014 Report Share Posted April 28, 2014 Do you means when you start Win8, you can see two operation options, one is Win8, another is Win Loader.exe? If yes, please press Win+R and type msconfig.exe, and press Enter. Click Boot, you will see two items, click Win Loader.exe then click Delete to remove it, or Set as default. Link to comment Share on other sites More sharing options...
xilolee Posted April 29, 2014 Report Share Posted April 29, 2014 translated from turkish: initial error I'm using Win8 initially shows two operating 1-Win8 2-w loader exe How can I fix "Win loader.exe" is probably a crack for the activation of Windows, and it could be infected with malware/virus. I.e., your system could not be genuine and not be under your TOTAL control. Be careful of what you do on internet! Don't use your sensitive data on internet, like when you are using your credit card or bank account. Suggestion: scan heavily your pc and correct this problem as soon as possible. Link to comment Share on other sites More sharing options...
