Posted
missing Msvcr80.dll Where can i find this file. I can't download itunes because i'm mising this file
I have windows 7
Operating system:Windows 7 Professional (32 bit) Service Pack 1
System root: C:\Windows
Available physical memory: 2551 MB
CPU: Intel® Core i5 CPU M 520 @ 2.40GHz
C: 452.65 GB
Internet Explorer: 11.0
Posted
There is a problem with the latest iTunes update which pops up error messages about two different missing .dll files.  They are not really missing.  If you check out the Apple Forums, you will see that many folks experiencing the same problem.  The solution is to remove/uninstall all Apple applications from your computer and then reinstall everything again.  Your error messages will disappear.  The problem is caused by the uninstaller for the version being updated deregisters a service before stopping it, which causes the upgrade to go sideways.
Hope this helps.  Have a great day.
Regards,
-Phil
