lenne Posted April 5, 2014 Report Share Posted April 5, 2014 ma caméra interne ne veut plus fonctionner (sur laptop Lenovo G570,windows7 ), j'ai dû effacer par mégarde quelque fichier!!!j'ai téléchargé Youcam + Lenevo easy camera, mais le problème persiste!! y a t'il une solution, s'il vous plait?? merci! Operating system:Windows Seven Black Edition (32 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3018 MB CPU: Intel® Core i3-2350M CPU @ 2.30GHz Drive Info: C: 97,56 GB D: 146,48 GB E: 221,62 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted April 26, 2014 Report Share Posted April 26, 2014 Hi lenne! The first thing that I asked myself is: what is windows seven black edition? After googling a bit I found that it is an illegal version of windows... Thus, I can't even try to help you because it is not allowed by forum rules (click). Anyway if you would have not mentioned that you had that version, it would have been difficult to help you (because it is already difficult to help with original software, that it is well known... Figure yourself with software that it is not well known!) For these problems, I must close the topic (nothing personal). PS: someone tells that version could contain trojans, malware... I think you should use some operating system that is not compromised. You can try linux or freebsd operating systems: they should be open source and free (most of the times). Link to comment Share on other sites More sharing options...
