Posted
fica abrindo um monte de janelas com este nome ( warning error 10060
Operating system:Windows 8 Single Language (64 bit)
System root: C:\Windows
Available physical memory: 3909 MB
CPU: Intel® Core i3-2348M CPU @ 2.30GHz
C: 449,19 GB
Internet Explorer: 10.0
Posted
Did the problem appear when you are surfing the internet?
In most cases,it not caused by user instead of sever. as user,you just can wait for a moment or a long time and then login again.
Posted
Hi renato! :)
If those webpages have been opened by themselves without your intervention, download/run these programs:
Full scan with your antivirus
adwcleaner (click)
Junkware removal tool (click)
superantispyware free (click)
sophos virus removal tool free (click)
MBAM free (click)
stinger 32 bit (click) or stinger 64 bit (click)
(according to your windows BIT version)
MS Safety Scanner 32 bit (click) or MS Safety Scanner 64 bit (click)
Keep us informed.
  • 3 weeks later...
Posted
The error 10060 means there is no response from the IP address of the website you are trying to access. Do you have Firewall software installed? Disable it. It might be your firewall that is blocking your connection. Or try the fix I found from the link below. See if it can help you. It provides more information regarding this issue.
http://www.techyv.com/questions/connection-timeout-error-11060-website
