mac.man85 Posted February 20, 2014 Report Share Posted February 20, 2014 الجهاز تقيل وتشغيل الافلام صعب قوي Operating system:Windows 7 Ultimate (64 bit) System root: C:\Windows Available physical memory: 2012 MB CPU: Pentium® Dual-Core CPU E5700 @ 3.00GHz Drive Info: C: 40.94 GB D: 141.61 GB E: 141.61 GB F: 141.60 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted February 21, 2014 Report Share Posted February 21, 2014 Hi mac.man85! 1) Download adwcleaner portable (click) and run it. 2) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 3) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it) 4) Double left-click wisecare365.exe, click custom checkup, select/tick all entries (or the entries that you prefer), click ok, click checkup now, wait until the scan finishes, click fix now. 5) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) 6) Launch sfc /scannow from an elevated command prompt 7) Defrag your hard disks (it may take hours... Try first the OS partition only). Keep us informed. Link to comment Share on other sites More sharing options...
