yu-e-t Posted February 17, 2014 Report Share Posted February 17, 2014 中時電子報的網頁開啟很慢```很慢`````很慢! Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 4078 MB CPU: Intel® Core i7-2630QM CPU @ 2.00GHz Drive Info: C: 679.86 GB D: 698.64 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted February 17, 2014 Report Share Posted February 17, 2014 Hi yu-e-t! 1) Download adwcleaner portable (click) and run it. 2) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 3) Create a system restore point (or let it create by WiseCare365, it should ask it to you the first time you run it) 4) Double left-click wisecare365.exe, click custom checkup, select/tick all entries (or the entries that you prefer), click ok, click checkup now, wait until the scan finishes, check the results, untick the ones you are not sure to fix, click fix now. 5) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) Keep us informed. Link to comment Share on other sites More sharing options...
