Posted
我的windows 8.1 有時候會卡死
就是開機完進入桌面後就直接沒反應 有時候還是會這樣
程式一開始都有幫助 但是到最後還是會出現卡死狀態
卡死狀態沒辦法攝取任何圖案
有機會再傳圖給你們 謝謝
Operating system:Windows 8.1 Pro (64 bit)
System root: C:\WINDOWS
Available physical memory: 6142 MB
CPU: Pentium® Dual-Core CPU E5400 @ 2.70GHz
C: 100.66 GB
D: 30.00 GB
E: 167.09 GB
Internet Explorer: 11.0
Posted
Hi a-fu! :)
1) Download adwcleaner portable (click) and run it.
2) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder.
3) Create a system restore point (or let it create by WiseCare365, it should ask it to you the first time you run it)
4) Double left-click wisecare365.exe, click custom checkup, select/tick all entries (or the entries that you prefer), click ok, click checkup now, wait until the scan finishes, check the results, untick the ones you are not sure to fix, click fix now.
5) Click the third tab at top: system tuneup
6) Launch sfc /scannow from an elevated command prompt (and wait that it finishes). If it shows errors, show them here.
7) (if you have BSODs, skip this) Defrag your hard disks (it may take hours... Try first the OS partition only).
Keep us informed.
Posted
In addition to the other suggestions, I would make a slight modification to one of xilolee's recommendations and add a step 6a as follows:
6a) If error are shown, before you show them here, please run the following command from and elevated command prompt:
Dism /Online /Cleanup-Image /RestoreHealth
6b) Once DISM is completed, run sfc /scannow and see if your errors have been fixed.
6c) Now, if you still have errors, please show them here.
