Wise Posted February 8, 2014 Report Posted February 8, 2014 Код64C произошла неизвестная ошибка Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 4060 MB CPU: Intel® Core i3-3240 CPU @ 3.40GHz Drive Info: C: 419,82 GB D: 511,59 GB F: 931,51 GB Internet Explorer: 11.0
David Bailey Posted February 8, 2014 Report Posted February 8, 2014 Код64C произошла неизвестная ошибка {Kod64C unknown error occurred} http://translate.google.com Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 4060 MB CPU: Intel® Core i3-3240 CPU @ 3.40GHz Drive Info: C: 419,82 GB D: 511,59 GB F: 931,51 GB Internet Explorer: 11.0
wisecleaner_admin Posted February 8, 2014 Report Posted February 8, 2014 Hi, I don't know which updates you install failed. There are two solutions of error code 64C, please have a try. Solution one: (From answers.microsoft ) Method 1: Microsoft has released a new "Fix it" solution that should automatically solve your problems with Windows Update. Just click the link below and follow the instructions. How do I reset Windows Update components? http://support.microsoft.com/kb/971058 Method 2: Follow the instructions in the link below to rename Software distribution and catroot folders and try to install the service pack. You cannot install some updates or programs http://support.microsoft.com/kb/822798 Method 3: Follow the instructions in the link below to reset Windows update components. How do I reset Windows Update components? http://support.microsoft.com/kb/971058 Method 4: Perform System File Checker (SFC) scan which will help you in resolving the issue. To determine whether the issue that you are experiencing is caused by one or more system files that are used by Windows Vista, run the System File Checker tool. The System File Checker tool scans system files and replaces incorrect versions of the system files by using the correct versions. Follow the instructions in the link below to run SFC scan. http://support.microsoft.com/kb/936212/ Solution two: (From blogs.msdn) If Silverlight isn't working for you and you are getting errors trying to either uninstall, reinstall or upgrade Silverlight the steps below will likely help you. Steps to clean up a machine to fix a broken Silverlight installation: 1, Copy these instructions to Notepad, Microsoft Word or some other text editor because you will be asked to close all browsers. 2, Click here to download and run Microsoft Fix it 3, Follow the instructions of Microsoft Fix it 4, Visit http://www.microsoft.com/getsilverlight and install Silverlight UCanFixIt 1
