kadi Posted February 3, 2014 Report Share Posted February 3, 2014 عدم القدرة على تنزيل جوجل كروم Operating system:Windows Se7en Titan (32 bit) System root: C:\Windows Available physical memory: 1014 MB CPU: Pentium® Dual-Core CPU E5400 @ 2.70GHz Drive Info: C: 146,48 GB D: 0,10 GB E: 146,62 GB K: 465,65 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted February 3, 2014 Report Share Posted February 3, 2014 Hi kadi! The first thing that I asked myself is: what is windows se7en titan? After googling a bit I found that it is an illegal version of windows... Thus, I can't even try to help you because it is not allowed by forum rules (click). Anyway if you would have not mentioned that you had that version, it would have been difficult to help you (because it is already difficult to help with original software, that it is well known... Figure yourself with software that it is not well known!) For these problems, I must close the topic (nothing personal). PS: someone tells that version could contain trojans, malware... I think you should use some operating system that is not compromised. You can try linux or freebsd operating systems: they should be open source and free (most of the times). Link to comment Share on other sites More sharing options...
