StefZZZ Posted January 29, 2014 Report Share Posted January 29, 2014 Summary Operating System Windows 7 Ultimate 64-bit SP1 CPU Intel Core 2 Duo E7200 @ 2.53GHz: 32 °C Wolfdale 45nm Technology RAM 4,00GB Dual-Channel DDR2 @ 398MHz (5-5-5-18) Motherboard BIOSTAR Group G31-M7 TE (CPU 1): 30 °C Graphics H-7005L2 ([email protected]) 512MB NVIDIA GeForce 8500 GT (Gigabyte): 47 °C Storage 931GB Western Digital WDC WD1002FAEX-00Z3A0 ATA Device (SATA): 31 °C After System Slimming default selected I use sfc /verifyonly & found corrupted files [sR] Cannot repair member file ,,, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing "Kalimba.mp3" of Microsoft-Windows-MusicSamples, "desktop.ini" of Microsoft-Windows-MusicSamples "Maid with the Flaxen Hair.mp3" of Microsoft-Windows-MusicSamples "Sleep Away.mp3" of Microsoft-Windows-MusicSamples "Koala.jpg" of Microsoft-Windows-PhotoSamples "Jellyfish.jpg" of Microsoft-Windows-PhotoSamples SampleRes.dll" of Microsoft-Windows-PhotoSamples desktop.ini" of Microsoft-Windows-PhotoSamples Desert.jpg" of Microsoft-Windows-PhotoSamples Lighthouse.jpg" of Microsoft-Windows-PhotoSamples Tulips.jpg" of Microsoft-Windows-PhotoSamples Chrysanthemum.jpg" of Microsoft-Windows-PhotoSamples Hydrangeas.jpg" of Microsoft-Windows-PhotoSamples Penguins.jpg" of Microsoft-Windows-PhotoSamples "Wildlife.wmv" of Microsoft-Windows-VideoSamples Clip_1080_5sec_VC1_15mbps.wmv" of Microsoft-Windows-WinSATMediaSamples Clip_480_5sec_6mbps_h264.mp4" of Microsoft-Windows-WinSATMediaSamples winsat.wmv" of Microsoft-Windows-WinSATMediaSamples "winsatencode.wmv" of Microsoft-Windows-WinSATMediaSamples, ..... after system restore created by wise care 365 sfc /verifyonly ...did not found any integrity problems but the sample files eg:(Kalimba.mp3) were not this was made in Virtualbox but i dont have the backup anymore So, is there any way to fix this problem without reinstall Windows ???? CBS.txt CBS.txt Link to comment Share on other sites More sharing options...
UCanFixIt Posted January 29, 2014 Report Share Posted January 29, 2014 Unfortunately, this issue has been reported before! See post #7 here: http://forum.wisecleaner.com/index.php?/topic/3090-wdc-affecting-sfc-scannow-results/ . Apparently, Wise Disk Cleaner is still offering all samples for removal as part of the slimming process; however, it appears that Win 7 considers them to be an integral part of the Windows 7 System; therefore, Wise Cleaner should not be offering to remove them to avoid the issue you are facing right now. The good new is that they are only "samples" and you can ignore those errors if you wish; however, you can try and recover your configuration by using the sfc /scannow command in conjunction with your Windows Installation DVD (if you have one) to try and fix those errors. See here for step by step instructions: http://www.sevenforums.com/tutorials/139810-sfc-scannow-run-command-prompt-boot.html If you don't have a Win 7 installation disc, you can download the proper version and create one from the downloaded ISO here: http://www.w7forums.com/threads/official-windows-7-sp1-iso-image-downloads.12325/ Once done, you can use that to run with sfc /scannow In summary, if the above does not work, you may be forced to do a repair install (if your really want your issue fixed). See here for instructions and what is affected: http://www.sevenforums.com/tutorials/3413-repair-install.html Good luck and let us know what you decide. ATTN admins: Can you follow up on this issue with development please? Link to comment Share on other sites More sharing options...
UCanFixIt Posted January 29, 2014 Report Share Posted January 29, 2014 You could also try using a system restore point to revert to a previous time (before you ran Wise Cleaner) if available. Link to comment Share on other sites More sharing options...
StefZZZ Posted January 30, 2014 Author Report Share Posted January 30, 2014 You could also try using a system restore point to revert to a previous time (before you ran Wise Cleaner) if available. Thanks for answer. Unfortunately I do not have it anymore. Good to know for next clean up! Link to comment Share on other sites More sharing options...
WiseCleaner Posted February 7, 2014 Report Share Posted February 7, 2014 Hi StefZZZ, Sorry to reply you late. If you do system restore by Wise care 365 or you don't have a system restore point, you can try following steps: E.g, Microsoft-Windows-MusicSamples 1, Open C:\Users\Public\Music, right click Sample Music folder (if you don't have it, create a new folder and named Sample Music), click Restore previous versions 2, Select an early point, click Restore. 3, Click OK. 4, Open C:\Windows\winsxs\, find out this folder *_microsoft-windows-musicsamples_* and do same operation as Sample Music folder Do you see, your sample music are restored. Microsoft-Windows-PhotoSamples C:\Users\Public\Pictures\Sample Pictures C:\Windows\winsxs\*_microsoft-windows-photosamples_* Microsoft-Windows-VideoSamples C:\Users\Public\Videos\Sample Videos C:\Windows\winsxs\*_microsoft-windows-videosamples_* C:\Windows\winsxs\*_microsoft-windows-winsatmediasamples_* Microsoft-Windows-WinSATMediaSamples C:\Users\Public\Recorded TV\Sample Media C:\Windows\winsxs\*_microsoft-windows-ehome-samplemedia_* UCanFixIt 1 Link to comment Share on other sites More sharing options...
