Posted
There are no sounds coming from the speakers but the volume controls shows there should be.
System root: C:\Windows
Available physical memory: 3037 MB
CPU: Pentium® Dual-Core CPU E5800 @ 3.20GHz
C: 451.72 GB
D: 13.94 GB
Internet Explorer: 11.0
Posted
Hi,
Please check following items:
1, Run all media players of your computer, check out whether you have set mute.
2, Update your sound card driver, or you can uninstall it then install the latest version.
3, Right click sound icon----click Playback devices----click your device, and set it as default.
Posted
Hi,
A nicely detailed suggestion based on minimum information from the OP!
