Posted
KHÔNG KHỞI ĐỘNG ĐƯỢC
System root: C:\WINDOWS
Available physical memory: 2013 MB
CPU: Pentium® Dual-Core CPU E5700 @ 3.00GHz
C: 14,65 GB
E: 22,61 GB
Internet Explorer: 8.0
Posted
Hi nguyenday! :)
Check screen resolution >= (Greater than or equal to) 1024x768
When you are going to install the program:
- Set the correct date/time on your system.
- Close every application, antivirus included (taskbar, systray, ...).
- Clean your pc (delete the files in the temp folders: [C:\Documents and Settings\<Admin/user>\local settings\Temp] and [C:\<WINNT>\Temp])
Keep us informed.
