Robes Posted January 26, 2014 Report Share Posted January 26, 2014 O computador trava constantemente tive um problema de não conseguir abrir nenhum programa ultrapassei isso agora trava em poucos segundos e volta ao normal depois trava de novo assim sucessivamente agradeço ajuda grato Robustiano Alves Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 1919 MB CPU: AMD Athlon 64 X2 Dual Core Processor 4200+ Drive Info: C: 232,88 GB D: 0,01 GB H: 465,76 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 28, 2014 Report Share Posted January 28, 2014 1, I guess you have installed a thirty-party antivirus software, suggest you to use MSE (Microsoft Security Essentials). It is smaller. 2, Run Wise Care 365----System Tuneup----System Optimizer, optimize your system 3, Run Wise Care 365----System Tuneup----Startup Manager, disable useless startup programs and services. 4, Run Wise Care 365----System Tuneup----Context Menu, disable useless context menus. 5, Run Wise Care 365----System Tuneup----Disk Defrag. you can do it every two months.(If your disk is SSD, please ignore this operation.) 6, Run Wise Care 365----System Tuneup----Registry Defrag. You can scan it every two months. If the scanning result says that you need to defrag registry, then you do it. 7, Run IE 8----Tools----Manage add-ons---Toolbars and Extensions, disable useless extensions. 8, Don't run more than three programs at the same time. Link to comment Share on other sites More sharing options...
