zoltan Posted January 23, 2014 Report Share Posted January 23, 2014 XP estében bejön a boot, aztán nagy sötétség és kb olyan 2perc!!!!!!!!!!!!!!! után észbe kap és bejön az asztal stb. milehet a gond????? Elöre is köszönöm a választ Operating system:Microsoft Windows XP (32 bit) Szervizcsomag 3 System root: C:\WINDOWS Available physical memory: 1791 MB CPU: Intel® Pentium® 4 CPU 2.40GHz Drive Info: C: 111,80 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 24, 2014 Report Share Posted January 24, 2014 It sounds like your XP system boot up very slow. You can try following steps to solve your problem. 1), Run Wise Care 365 to clean junk files. 2), Run Wise Care 365----System Tuneup---System Optimizer, optimize system 3), Run Wise Care 365----System Tuneup---Startup Manager, disable useless startup programs. Make sure all services that we suggest to Enable is ON. 4), Run Wise Care 365----System Tuneup---Context Menu, disable useless context menus. 5), Run Wise Care 365----System Tuneup---Disk Defrag. BTW, if those cannot work, please your disk: Click Start---Run, type cmd and press Enter, then type chkdsk c: /f Link to comment Share on other sites More sharing options...
