abdalrhman Posted January 9, 2014 Report Share Posted January 9, 2014 عند مشاهد فيديو على اليوتيوب او لعب لعبه اونلاين تتم غلق اللعبه ويظهر لى هذه الرساله Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 502 MB CPU: Intel® Core2 CPU 6300 @ 1.86GHz Drive Info: C: 9.76 GB D: 64.73 GB Internet Explorer: 7.0 Link to comment Share on other sites More sharing options...
xilolee Posted January 10, 2014 Report Share Posted January 10, 2014 Hi abdalrhman! Have you sent the crash report?From Adobe Flash Player 11 Tech specs - Windows: 2.33GHz or faster x86-compatible processor, or Intel® Atom™ 1.6GHz or faster processor for netbooksMicrosoft® Windows® XP (32 bit), Windows Server 2008 (32 bit), Windows Vista® (32 bit), Windows 7 (32 bit and 64 bit), Windows 8 (32 bit and 64 bit), or Windows Server 2012 (64 bit)Internet Explorer 7.0 or later, Mozilla Firefox 17 or later, Google Chrome, or Opera 11512MB of RAM (1GB of RAM recommended for netbooks); 128MB of graphics memory It seems that your PC does not meet the minimum requirements...Anyway, you can try:1) uninstall flash player completely, reset your browser to its default settings, reinstall flash player2) create another browser profile and remove the current browser profile3) disable the hardware acceleration inside your browser settings4) enable software rendering to see if this helps: Control Panel, Network and Security, Internet Options, Advanced tab and then Accelerated Graphics, tick Use software rendering instead of GPU rendering, click Apply/OK Link to comment Share on other sites More sharing options...
