t122480205 Posted January 6, 2014 Report Share Posted January 6, 2014 伺服器無法執行,畫面出現{26EE0668-A00A-44DA-9371-BEB064C98683}等字樣,無法點即進入桌面任一程式,也無法進入控制台 Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 7882 MB CPU: Intel® Celeron® CPU G550 @ 2.60GHz Drive Info: C: 292.87 GB D: 292.97 GB E: 345.57 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted January 7, 2014 Report Share Posted January 7, 2014 Hi t122480205! 1) Scan your system with these softwares (and let us know if they find anything): Full scan with your antivirus adwcleaner (click) Junkware removal tool (click) superantispyware free (click) sophos virus removal tool free (click) MBAM free (click) stinger 32 bit (click) or stinger 64 bit (click) (according to your windows BIT version) MS Safety Scanner 32 bit (click) or MS Safety Scanner 64 bit (click) (according to your windows BIT version) 2) try to launch sfc /scannow from an elevated command prompt (and let us know if it finds anything): 3) Have you installed any new softwares in these past days? 4) try to start your pc in safe mode and see if it happens the same. If it works in safe mode, try a clean startup 5) possible corrupted Windows profile: try to create another profile and see if it helps Link to comment Share on other sites More sharing options...
