DNS Posted January 4, 2014 Report Posted January 4, 2014 ошибка приложения Operating system:Windows 8.1 Single Language Preview (64 bit) System root: C:\WINDOWS Available physical memory: 8073 MB CPU: Intel® Core i7-3630QM CPU @ 2.40GHz Drive Info: C: 107,97 GB D: 356,93 GB Internet Explorer: 11.0
UCanFixIt Posted January 4, 2014 Report Posted January 4, 2014 ph01.exe is a proprietary data recovery program. If you have paid for this program and it does not work as designed, I would recommend contacting their support directly: http://www.corrupteddatarecovery.com/File-Data/ph01.exe-ph01-FileSubmit-1.0.0.asp
xilolee Posted January 4, 2014 Report Posted January 4, 2014 Hi dns! Please send the complete error (write it), because I can not read it entirely and my russian is quite rusty. Anyway, I can't find useful informations about it. Pegatron website seems to not help neither (pegatroncorp.com ?). It seems a file related to Hotkey - Pegatron's driver for wireless network keys and GPU switch key. It doesn't seem a malware. Probably it is not compatible with Windows 8.1, so the following procedure could help to solve the problem: Press both Windows key and R key (Windows + R): it opens the run window Type/copy: services.msc (press enter) Stop and disable Windows Driver Foundation - User-mode Driver Framework Restart your machine
