Dani Posted December 29, 2013 Report Posted December 29, 2013 Driver_power_state_failure Lenovo Flex 15 Windows 8.1 4gb Ram Operating system:Windows 8.1 (64 bit) System root: C:\WINDOWS Available physical memory: 3816 MB CPU: Intel® Core i3-4010U CPU @ 1.70GHz Drive Info: C: 425,09 GB D: 25,00 GB Internet Explorer: 11.0
WiseCleaner Posted December 30, 2013 Report Posted December 30, 2013 Hi, This error message means that you have install a non-Signature driver (Not WHQL) 1, Uninstall drivers that you installed recently. 2, Make sure all installed drivers has WHQL signature. If these steps cannot work, do a thumbnail of the error message and send to us. If this error is blue screen of death, send this file to us (c:\windows\minidump\*.dump)
Dani Posted January 21, 2014 Author Report Posted January 21, 2014 Driver_Power_State_Failure Hi Ich habe folgendes Problem mein Lenovo Flex 15 Notebook Stürzt sporadisch ab mit der Fehlermeldung Driver_Power_State_Failure habe meine Treiber alle Aktualiesiert und auch alle Updates von Windows. Mein System: Windows 8.1 4GB Arbeitsspeicher Core I3 Nvidia geforce 720M Thx Operating system:Windows 8.1 (64 bit) System root: C:\WINDOWS Available physical memory: 3816 MB CPU: Intel® Core i3-4010U CPU @ 1.70GHz Drive Info: C: 425,09 GB D: 25,00 GB Internet Explorer: 11.0
WKK Posted January 22, 2014 Report Posted January 22, 2014 Hi Dani, Have you installed any antivirus software? Which anti-virus software are you using? Maybe, your problem is caused by antivirus software.
