mutlu Posted December 11, 2013 Report Share Posted December 11, 2013 İnternette ki hemen hemen tüm çözüm yöntemlerini denedim fakat ne regedit ne de görev yöneticisini çalıştırmayı başaramadım. Operating system:Windows 7 Ultimate (32 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3039 MB CPU: Intel® Core2 Duo CPU T6600 @ 2.20GHz Drive Info: C: 195,21 GB D: 270,45 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted December 11, 2013 Report Share Posted December 11, 2013 Turkish: Görev Yöneticisi Ve Regedit Açılmıyor İnternette ki hemen hemen tüm çözüm yöntemlerini denedim fakat ne regedit ne de görev yöneticisini çalıştırmayı başaramadım. error displayed: görev yöneticisi yöneticiniz tarafından devre dışı bırakıldı English: It does not open Task Manager and Regedit On the Internet have tried almost all the methods of solution, but what I failed regedit nor run task manager. error displayed: Task Manager has been disabled by your administrator Hi mutlu! The simpler thing you can do to regain access to your regedit.exe is to rename it. Try to rename regedit.exe in another way (like Alaska.exe) and start it with that name. The second one is to try to use gpedit.msc (Windows key + R key opens the run window, type gpedit.msc, press enter): go to User Configuration --> Administrative Templates --> System, in the right pane select Prevent access to registry editing Tools and set it to Not configured or Disabled. Third: have you already tried the proposed solutions inside wise pc 1st aid (both for regedit and task manager)? Fourth: other tools listed in techdows.com - 7 Ways to Fix ”Registry editing has been disabled by Your administrator “ (click) When you will have recovered your registry editor, you can follow these topics on Microsoft support (even if they are talking about Windows xp, I think they apply to other OS too): "Task Manager has been disabled by your administrator" error message Error message when you try to open Task Manager on a Windows XP-based computer: "Task Manager has been disabled by your Administrator" Looking forward for your kind feedback! Link to comment Share on other sites More sharing options...
