QAW321123 Posted November 30, 2013 Report Share Posted November 30, 2013 問題.更加嚴重.本來開機都.會跑出.一個錯誤訊息..現在變跑出來5-6個...還好關得掉...不然就完了... Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 2039 MB CPU: Intel® Core2 Duo CPU E4500 @ 2.20GHz Drive Info: C: 78.13 GB D: 372.36 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted November 30, 2013 Report Share Posted November 30, 2013 Hi qaw321123! I didn't understand the problem that you have got: which program are you using? Googling the number 0x7c939af2 shows that it is an asian problem most of the times, so I suspect that it could be an unicode problem related. Try to fix it with sfc /scannow (from the command prompt). It could asks you the windows xp original installation cd. Try to search for malware, using the following programs: adwcleaner (click) Junkware removal tool (click)superantispyware free (click)sophos virus removal tool free (click)MBAM free (click)stinger 32 bit (click) or stinger 64 bit (click)(according to your windows BIT version)MS Safety Scanner 32 bit (click) or MS Safety Scanner 64 bit (click)(according to your windows BIT version) Or explain yourself better! Looking forward for your kind feedback! Link to comment Share on other sites More sharing options...
