Posted
Hello,
My laptop hdd bad sector problem, and when there is a warning boot entry to be taken to the service center, if I can fix the problem yourself? what is the best solution?
Thank You
Operating system:Windows 7 Ultimate (32 bit)
System root: C:\Windows
Available physical memory: 1894 MB
CPU: Intel® Core i3-2310M CPU @ 2.10GHz
C: 293,94 GB
F: 223,51 GB
Internet Explorer: 8.0
Posted
Hi nanang!
The following operations make only a scan to your HDDs:
- Open command prompt with elevated privileges, type chkdsk C: (press enter key on your keyboard), check the result.
- Do the same for F: --> chkdsk F:
If those ones found bad sectors, you could try to recover them with either chkdsk /b [insert the corrupted hdd letter] OR chkdsk /r [insert the corrupted hdd letter]
More informations: http://technet.microsoft.com/en-us/library/cc730714.aspx
Later, after a reboot, open command prompt with elevated privileges, type sfc /scannow (press enter key on your keyboard), check the result.
See you!
