my2cents 5 Posted October 16, 2013 Report Share Posted October 16, 2013 Hello all, Since I do not use System Restore points, is there any way to disable WDC from automatically creating one before attempting file removals under certain conditions. I always go back in and disable System Restore and delete the newly created restore point but it seems like an option should be made available for those of us that rely more on a System Image restoral to fix our issues. A great product BTW! Thanks, my2cents nohnigefearxv76 1 Link to post Share on other sites
WiseCleaner 1,130 Posted October 17, 2013 Report Share Posted October 17, 2013 Hi, WDC create a system restore point automatically only the user use the function "Slimming System" . This is a measure for safety, letting users to use system restore point to get back files which has been deleted accidently. Link to post Share on other sites
my2cents 5 Posted October 17, 2013 Author Report Share Posted October 17, 2013 Hello admin, OK, yes I noticed that it was a conditional and automatic function; however, even though I would prefer to have an option to disable it, I can certainly understand you concern for the general safety of all users, so I can accept that logic and just continue to disable it after a slimming function. Thank you for your explanation and you have a great product line BTW! my2cents Link to post Share on other sites
liznamany 0 Posted January 8, 2014 Report Share Posted January 8, 2014 I have a free Wise disk cleaner 7 (Russian vers. 7.99.570), I use wind7 professional SP1. I tried to use Slimming system (Очистка системы), system response: Не удалось создать точку восстановления. Сообщение об ошибке 2130706175. (Restore point can't be created. Error 2130706175). I haven't found the solution for this error and would be really thankful if help me sending easy instructions. Link to post Share on other sites
wisecleaner_admin 1,340 Posted January 17, 2014 Report Share Posted January 17, 2014 Hi Liznamany, Please check two points: 1, Right click My Computer----Properties----System Protection-----click C:----Configure, check your settings. Then check disk space of C, whether it has enough space. 2, Open Control Panel---System and Security----Administrative Tools---Services, find out Volume Shadow Copy service and make sure its status is Started. 3, If those cannot solve your problem, please show us a thumbnail of the error message (Restore point can't be created. Error 2130706175) Link to post Share on other sites
