Wise_EPL Posted September 29, 2013 Report Posted September 29, 2013 Windows Explorer Not IE still does> When I click on "Rate This Computer", Windows Explorer restarts. And then when I right click on Computer>Properties, Windows Explorer restarts. Why does it do that & what's the fix for it? (Try Picturing it in your mind) < It's seems impossiable to take a snapshot of the problem when Windows Explorer restarts. Operating system:Windows 8 Pro with Media Center (32 bit) System root: C:\WINDOWS Available physical memory: 3071 MB CPU: Intel® Core2 Duo CPU E7500 @ 2.93GHz Drive Info: C: 465.76 GB Internet Explorer: 10.0
april Posted September 29, 2013 Report Posted September 29, 2013 Could you tell us which software did you install that causing this issue? Thank you for your information.
wisecleaner_admin Posted September 29, 2013 Report Posted September 29, 2013 And you can restart your system ---press F8 , run system in safe mode, and rate computer.
