Easy Posted April 30, 2024 Report Posted April 30, 2024 Hi, Latest PORTABLE version 11.1.1.826 is messed up, as it is not acting as previous portables. It does not read correctly previous configuration files from version 11.0.9.823 and is not 'remembering' configuration changes ('Common Cleaner' selections, drives in 'Advanced Cleaner', ...). It is also 'filling' data in folders '%APPDATA%\Wise Disk Cleaner', '%APPDATA%\Wise Utilities' and '%APPDATA%\Wise Euask' and sometimes creates new file 'Types.lst' in folder %APPDATA% instead of using one in program folder. There could be some other problems, but I did not investigate further because I went back to version 11.0.9.823 Regards
wisecleaner_admin Posted May 7, 2024 Report Posted May 7, 2024 Dear user, Sorry about that. The portable version will only read the configuration files (Config.ini) from its own installation folder, it will not read the previous software's configuration files. The Types. lst file in the AppData folder exists reasonably indeed, which explains the Advanced Cleaner's Advanced Settings, you can open it with Notepad. smarttips and chloe34 1 1
Easy Posted June 1, 2024 Author Report Posted June 1, 2024 On 5/7/2024 at 9:24 AM, wisecleaner_admin said: ... The Types. lst file in the AppData folder exists reasonably indeed,... Yes it is needed, but it should be located in program folder, like all other configuration files in portable version. That file is placed in program folder in latest version, but ... Latest PORTABLE version 11.1.2.827 is also not remembering selections in 'Common Cleaner', for example 'Oracle VM VirtualBox Manager'. Even if it 'writes' in config.ini: [CheckedTypes] OracleVMVirtualBox =1 On next run it is unselected. Maybe problem is in space ' ' written before '=' or something else. I tried to remove that space with no result. Program again ignored selection and changed that by inserting space before '=' It also does not remember selected drives in 'Advanced Cleaner', for example only drives C:\, D:\ and E:\ are selected: [General] Locations=Local Disk(C:\; D:\; E:\ ) But on next run all attached drives are automatically selected, and in config.ini line is automatically changed to: Locations=Local Disk(C:\; D:\; E:\; G:\; K:\; L:\ ) This time I used 'clean' configuration files from ZIP portable version and completely configured again. I'm forced to use latest portable version 11.0.9.823 which does not have mentioned problems. Otherwise I have to configure it completely on every new run. Again, did not check all other settings because this was enough for me not to use this version. EDIT: Exactly same problems are with PAF version (11.1.1 and also new 11.1.2) from 'PortableApps.com' https://portableapps.com/apps/utilities/wise-disk-cleaner-portable smarttips 1
Easy Posted June 3, 2024 Author Report Posted June 3, 2024 What is this https://forum.wisecleaner.com/index.php?/topic/18706-wise-disk-cleaner-1111826-portable/&do=findComment&comment=45635 and who approved this post?
wisecleaner_admin Posted June 5, 2024 Report Posted June 5, 2024 Dear user, Sorry for any inconvenience caused. We have reported your feedback to the Software R&D team. We will fix it in the next update. Have a good day. Easy 1
Easy Posted July 6, 2024 Author Report Posted July 6, 2024 In latest portable version 11.1.3.829 mentioned problems seems to be solved.
wisecleaner_admin Posted July 8, 2024 Report Posted July 8, 2024 Dear user, Thank you for your feedback. Have a good day.
Easy Posted July 15, 2024 Author Report Posted July 15, 2024 Hi, But now I've noticed that latest PORTABLE version 11.1.3.829 is ignoring file 'Types.lst' located in program folder, and is creating new file in %APPDATA% folder. Not any subfolder. Should I open new ticket, because for me, it is related to same problem with portable version handling configuration files?
wisecleaner_admin Posted July 26, 2024 Report Posted July 26, 2024 Dear user, Sorry for any inconvenience caused. Please try this: 1. Press Win + R to open the run dialogue 2. Type in %appdata%, then click OK to run 3. Find the Wise Disk Cleaner by following this path, then delete it 3. Install the latest 11.1.3 version of Wise Disk Cleaner: https://downloads.wisecleaner.com/soft/WDCFree_11.1.3.829.exe smarttips 1
Easy Posted July 27, 2024 Author Report Posted July 27, 2024 I deleted that mentioned file, as I found and described location to you (in my previous post). I do not want to install program, but I'm using portable (ZIP) version, which is causing this problem. Version you suggested (11.1.3) is the same as portable (11.1.3.829) mentioned in my previous post and causing this problem.
wisecleaner_admin Posted August 1, 2024 Report Posted August 1, 2024 Dear user, Sorry for any inconvneience caused. The following is the latest version: https://downloads.wisecleaner.com/soft/WDCFree_11.1.4.830.zip
Easy Posted August 1, 2024 Author Report Posted August 1, 2024 With this portable version 11.1.4.830 is same situation as with previous. It is not using file Types.lst in program folder, but creates new file in %APPDATA% folder if custom locations are added.
wisecleaner_admin Posted August 20, 2024 Report Posted August 20, 2024 Dear user, Sorry for not replying sooner. We tested and found the Type.lst file will be ceated under %Appdata% folder rather than under Wise Disk Cleaner folder. Although it will not affect the Advanced Cleaner's operation, we have reported it to the Software R&D team. Have a good day. Easy and smarttips 1 1
Easy Posted August 21, 2024 Author Report Posted August 21, 2024 Thanks, but it is affecting operation, because all previous entries in file located in program folder are ignored, and new empty file is created in %APPDATA% folder. To use those 'old' entries, file 'Types.lst' should be copied from program folder to %APPDATA% folder (just advice as temporary solution for other users).
Easy Posted September 27, 2024 Author Report Posted September 27, 2024 Also in portable version 11.1.6.832 problem with 'Types.lst' file location is not solved. Any chance for some actual and useful response?
Easy Posted October 18, 2024 Author Report Posted October 18, 2024 Hi, Now is almost 6 months since I reported this confirmed bug. If your 'Software R&D team' is not able to solve this problem, please give them my email to contact me, and I will help them to solve this. Regards
wisecleaner_admin Posted October 24, 2024 Report Posted October 24, 2024 Dear user, Sorry for any inconveniece casued. We will fix this portable version issue in the next update. Have a good day.
