Xris09 Posted March 9 Report Share Posted March 9 Hello!,. I would need to know what command I can use in "Wise DuplicateFile" , to add it to the "Windows Context Menu" and redirect the search to the corresponding folder. I'm trying to do this, but I need to know the correct parameter ... ;--------------------------------- Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\Directory\shell\DuplicateFileFinder] "MUIVerb"="DuplicateFileFinder" "Position"="Middle" [HKEY_CLASSES_ROOT\Directory\shell\DuplicateFileFinder\command] @="C:\\Program Files (x86)\\Wise\\Wise Duplicate Finder\\WiseDuplicateFinder.exe \"%1\"" ;--------------------------------- I need to know the parameter before \"%1\"" If someone can help me, it would be of great help, thank you! As an extra fact, I discovered that the file located in.... C:\Users\Admin\AppData\Roaming\Wise Duplicate Finder\Config.ini In the next line, it tells you which path to set..... [InPath] C:\= Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 14 Report Share Posted March 14 @Xris09 Hello, Thanks for your share. But Wise Duplicate Finder does not have such a parameter. We will add it in the next updates. Sorry. Xris09 1 Link to comment Share on other sites More sharing options...
